joeycatt's Avatar
Talking 2 hours to remove...Should I repaint them?
2 grim hours to wrench, saw and drill these heater boxes out of my SC. Looks like Ohio salt did a job, huh?
What do you think....repaint ? I'm thinking maybe 64 coats of POR15 and they'll be near-new.....
Looks like a trip to the "heater boxes for sale" list for me!!!
Old 08-06-2006, 06:05 PM
WPOZZZ's Avatar
Heater? We don't need no stinkin' heater.
Old 08-06-2006, 06:10 PM
joeycatt's Avatar
Heat for Snow ?
WPOZZZ
Oh, Man .....Honolulu.... how about shipping me a set of "like new" heater boxes and I'll send you some snow !!!
joeycatt.
Old 08-06-2006, 06:32 PM
dtw dtw is offline
GAFB
Wow! I've never seen a pair that bad.
I've got a slightly less-rusty pair for sale, see this thread:
HUGE parts sale - various new & used parts, something for everyone
Several BMWs
Old 08-06-2006, 06:38 PM
WPOZZZ's Avatar
Re: Heat for Snow ?
Originally posted by joeycatt
WPOZZZ
joeycatt.
We have snow here, but it's on a different island. However, whenever I get that Carrera, the heater stuff is coming out. I have headers on the way.
Old 08-06-2006, 06:59 PM
theclaw's Avatar
Hey, I live in Chicago. Heater stuff is coming out as we speak. Tiddies up the engine. Besides, the garage is heated.
jeff
'84 Carrera (recently sold )
'67 MB 250SL
A few Italian motorcycles
......and a minivan for the crew
Old 08-06-2006, 07:03 PM
dtw dtw is offline
GAFB
Slightly less rusty
Several BMWs
Old 08-06-2006, 07:08 PM
skinnerd's Avatar
definitely buy a new set
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 08-06-2006, 07:21 PM
Somewhere in the Midwest
MotoSook's Avatar
That's art, John Get them bronzed and use them at the office for paper weights Looks like you're making progress on the car...naice.
Old 08-06-2006, 07:32 PM
Goth's Avatar
Are those the light weight racing version?
Doug
84 Carrera Coupe - Black (the Goth look)
The more I learn, the more I realize I don't know
Old 08-06-2006, 08:32 PM
Hey....are you going to have that back together for the DE track day at Nelsons Wednesday? Shouldn't need heat....should be in the 80's.
My heat has some "issues"...it has that automatic thing with the motor driven cables....but I don't drive it in the winter. Ohio is hard on cars in the winter. Brian
79'SC Euro
90', 92' MX5 Miata
06' Dodge 3500 QC 4x4 Cummins
Old 08-07-2006, 02:49 AM
19 years and 17k posts...
azasadny's Avatar
Ouch! I cleaned up mine while my engine was out in July and mine weren't close to that bad, but the car is from CA, so that helps a little, and I don't drive it in the rain/snow/salt...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 08-07-2006, 12:17 PM
304065's Avatar
Watch out: this part has been superceded many times and the old ones are different from the new. Make sure what you buy is identical.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 08-07-2006, 12:19 PM
Nine9six's Avatar
I've seen that before...It'll clean right up with a little rubbing compound.
Just be sure not to use the heavy grit stuff, as you wouldn't want to damage the finish.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 08-07-2006, 01:00 PM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
I just replaced mine. Got Dansk ones from Pelican- less expensive than those listed. Just ask. BTW, getting the rear upper nut on is a *****! Especially if you have AC.
Update: Oh my god. I've been bleeped!
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 08-07-2006, 01:15 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
If you heater boxes looked that bad, have you looked at the cage under your smuggle's box?
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 08-07-2006, 01:29 PM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
just wrap them in duct tape....isnt that what that stuff is for anyway?
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 08-07-2006, 04:15 PM
