-   -   Used 3.0 Long Block Value? (http://forums.pelicanparts.com/porsche-911-technical-forum/297053-used-3-0-long-block-value.html)
TOO RUF 08-04-2006 04:12 PM
Thinking about upgrading to a 3.2. What value would a strong running 3.0 Long Block be? It has oil leaks and needs either rings or valve guides. The compression is about 130.
JP911 08-04-2006 04:58 PM
Check recent sales in the classifieds forum, but running 3.0 long blocks go from anywhere between $3K and $6K depending on the condition. Someone looking to make a swap may not be very interested in having to do a top end job to replace the rings and/or guides, but it would be a great candidate for a rebuild or hotrod.
TOO RUF 08-04-2006 05:00 PM
Thanks. That price is just the long block. No intake,exhaust, alternator, etc.
Jeff Alton 08-04-2006 11:40 PM
Probably worth more to sell off the pieces. If it needs a rebuild the value goes down a fair bit. But here is some ballpark prices for some stuff that would sell quickly...... (prices may be undervalue to some)
Case 1000
Crank/rods 750
Heads 600
cams 100
oil pump 100
oil cooler 125
cams 75-100
cam towers 150
upper valve covers 25
lower turbo covers 50
rockers/shafts/bolts 75
chain boxes 50
intermediate shaft 50
Piston/cylinders anywhere from 0-300
Just gives you an idea of what some stuff *might* go for. You may get more for some of the stuff too!
Cheers
Wayne 962 08-05-2006 01:22 AM
If it needs rebuilding, $2K-$3K max, for the longblock...
-Wayne
TOO RUF 08-06-2006 12:19 PM
Great Thanks. This will give me an idea so I can decide if I am going to upgrade.
