TOO RUF's Avatar
Used 3.0 Long Block Value?
Thinking about upgrading to a 3.2. What value would a strong running 3.0 Long Block be? It has oil leaks and needs either rings or valve guides. The compression is about 130.
15 Cayman
93 Amethyst 964 Cab & 67 21 window VW Wife's
64 356
69 912 targa
68 911L Hot Rod
Old 08-04-2006, 04:12 PM
Check recent sales in the classifieds forum, but running 3.0 long blocks go from anywhere between $3K and $6K depending on the condition. Someone looking to make a swap may not be very interested in having to do a top end job to replace the rings and/or guides, but it would be a great candidate for a rebuild or hotrod.
Old 08-04-2006, 04:58 PM
TOO RUF's Avatar
Thanks. That price is just the long block. No intake,exhaust, alternator, etc.
15 Cayman
64 356
69 912 targa
68 911L Hot Rod
Old 08-04-2006, 05:00 PM
Jeff Alton's Avatar
Probably worth more to sell off the pieces. If it needs a rebuild the value goes down a fair bit. But here is some ballpark prices for some stuff that would sell quickly...... (prices may be undervalue to some)
Case 1000
Crank/rods 750
Heads 600
cams 100
oil pump 100
oil cooler 125
cams 75-100
cam towers 150
upper valve covers 25
lower turbo covers 50
rockers/shafts/bolts 75
chain boxes 50
intermediate shaft 50
Piston/cylinders anywhere from 0-300
Just gives you an idea of what some stuff *might* go for. You may get more for some of the stuff too!
Cheers
www.turn3autosport.com
Old 08-04-2006, 11:40 PM
TOO RUF's Avatar
Great Thanks. This will give me an idea so I can decide if I am going to upgrade.
15 Cayman
64 356
69 912 targa
68 911L Hot Rod
Old 08-06-2006, 12:19 PM
