-   -   Deceleration Valve defective? (http://forums.pelicanparts.com/porsche-911-technical-forum/297140-deceleration-valve-defective.html)
safe 08-05-2006 08:56 AM
Hi
My idle is way to high, ~18-2000 rpm.
If I squeeze the top vacuum hose together the idle drops to a more normal rpm.
With that description is it safe to say that its kaputt?
http://forums.pelicanparts.com/uploa...1154793184.jpg
Its kind of expensive, I guess I can live without it. If I remove it I should plug all vacuum hoses right?
stlrj 08-05-2006 10:37 AM
Guess what, it's adjustable! Back off the locknut and turn in the stem clockwise to increase the spring tension against the diaphram 'til you get it to idle.
safe 08-05-2006 11:37 AM
I'll try that.
I read about it but I thought it only controlled the rpm it held for a few seconds.
safe 08-21-2006 08:41 AM
Adjusted it and it now workes fine!
I have to remove it and put it in a vice to break the lock nut free.
stlrj 08-21-2006 08:58 AM
Glad you were able to save a few bucks ( or whatever they are in Sweden).
Joe
safe 08-21-2006 09:04 AM
Actually I'm not sure the "adjusting" fixed the problem.
It is adjusable, the revs and time changed when I turned stem, but when have broken loose the lock nut and reinstalled it the problem was gone. I guess it just needed a good spanking ;)
