Tire Experts - Opinion Please
Sorry to start a new thread on this, but after much reading, I'm still nervous.
I am thinking about going from 16" to 17" wheels because the tire selection has really gone done in the last year. I currently have Pilot Sports in 205/55R16 and 225/50R16 - NLA.
Mostly street driving, some autocrosss. Lowered about 0.5 below Euro, -1 (F), -2 (R) camber. My goal is not max. rubber in the wheel wells. What I want is good selection of tires and no chance of rubbing. I have found some wheels for a reasonable price. Does this look OK:
17x7.5 +23mm 205/50R17
17x9 +15mm 245/40R17
All suggestions welcome. Thanks for any help.
Scott Wilburn
1988 911 Carrera 3.4 L
1998 M3
1984 308 QV
Old 08-05-2006, 10:01 AM
Mad scientist
Peter Bull's Avatar
The offsets look a little on the short side. My 17" wheels have 30.4 and 17.7 mm offset front and rear respectively. They are 8" and 9" wide.
There is a thread on Rennlist.org which may be of interest.
/Peter
'84 911 Carrera
'91 928 S4
You can't make a racehorse out of a bull, but you can make an awfully fast bull.
Old 08-05-2006, 10:21 AM
rfuerst911sc's Avatar
I have 17 inch Borbets as my street rims in I believe the same offset as you are listing. Mine are 7.5 + 9 inch wide and I have 225/45 + 255/40 Fuzion tires with a lowered car and they fit fine but the front lips did have to be rolled for clearance.
Old 08-05-2006, 11:44 AM
durn for'ner
livi's Avatar
If you would consider staying with 16 rims and Michelin, I would recommend Pilot Exalto. Thats what I got in that dimension after my almost ten years old Pilot Sport. I am very pleased with them. Of course, I have not been to the track with them yet.
Markus
Resident Fluffer
Carrera '85
Old 08-05-2006, 12:15 PM
Bill Verburg's Avatar
That will fit fine, the left front lip will be close, some cars have more of an issue than others.
The 17s you have chosen are actually shorter than what you now have on your car. the front ny ~.5" the rears by ~.1",
the car will have a slightly more of nose down attitude, but not a problem at all.
There is something not being mentioned about the car on Rennlist, I don't know what it is but there is more to the story than has been stated so far.
When the wheel width is increased the ET or o/s must also increase to keep the wheel in the same position in the wheel well.
+23.3mm is what the front wants for 7 or 7.5 w/ the 7.5 w/ that o/s has its outer edge pushed ~.25" further outboard.
+15mm is what a 9" rear on an SC/Carrera flared car will want. Some even use up to ~15mm of spacers to futrther move the outer edge ouboard(not recomended but it has been done)
Bill Verburg
Old 08-05-2006, 12:34 PM
aj88cab's Avatar
Hi folks
Don't know if I can add anything of value to this discussion but I had these "calculator" links saved that might be of some help. The "wheel size" calculator has been referenced before I'm sure, the "off-set" calulator I have not seen before.
Wheel Offset Calculator
Tire Size Calculator
Now I'm off to the garage and 98 degree heat to switch wheels, getting a new set of RA1 track tires Monday. Woohoo!
Good luck,
Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 08-05-2006, 01:39 PM
Halm's Avatar
Re: Tire Experts - Opinion Please
I guess I am a little confused here. What tire are you looking for? I just ran a "select by size" scan on Tire Rack and exluding winter and track tires there are 71 to pick from in the 225/50 size. Compared to what I can get in the 245/45 size (8), it looks to me that you hit the mother load. Is there a particular tire you want or need?
'17 Cayenne
Old 08-05-2006, 01:43 PM
I was trying to replace the Pilot Sports I have now. I'm leaning now toward Goodyear Eagle F1 GS-D3.
I've also never been very happy with the wheels that the PO put on the car: Design 90's. Looked like a good opportunity to get better looking wheels, 17", and a better selection of high-performance tires.
The downside is the front tires are almost new and I was planning on spending the money on a TBitz EFI system.
I'll probably go with the Goodyears for now and consider again the next time.
Scott Wilburn
1998 M3
1984 308 QV
Old 08-05-2006, 02:46 PM
Halm's Avatar
Makes perfect sense now. I "assumed" you were running Fuch's. Picking an 17" aftermarket wheel that will look right on a SC will be a fun project. Be sure to keep us posted on what you do. I know I will be faced with that decison sooner than I want.
'17 Cayenne
Old 08-05-2006, 02:53 PM
I'll reopen this thread when the front tires are worn!
Scott Wilburn
1998 M3
1984 308 QV
Old 08-05-2006, 03:18 PM
