-   -   Floating at 60mph?? (http://forums.pelicanparts.com/porsche-911-technical-forum/297626-floating-60mph.html)
Hurra912 08-08-2006 07:42 AM
Floating at 60mph??
When my '69 gets up to cruising speed, it starts to float from side to side. The steering feels tight, but obviously something needs attention. Tie-rods, bushings, alignment?
Wayne
Oh Haha 08-08-2006 08:34 AM
Check it all. Old bushings will certainly cause some weird handling.
Gasman59 08-08-2006 08:42 AM
Wayne, I have the same problem, but only when there is a big truck (tractor-trailer) in front or beside me at highway speeds.
I was told in the early porsche this is normal as the air flow dynamics get all screwed up.
Is this incorrect??
Thanks,
Ron Y
1970 911 E Targa
Hurra912 08-08-2006 08:49 AM
If this is normal, is the castor neutral on the car? Could it be adjusted to center itself on the road better.
Rot 911 08-08-2006 09:01 AM
Too much toe out will exhibit itself in the symptoms you describe. You should also be able to feel it at lower speed. In any event an alignment is in order.
defcon65 08-08-2006 09:14 AM
I had the same handling symptoms and the problem vanished with new shocks and TT rods plus an alignment. I checked the stabilizer bar bushings and they looked to be in pretty good shape so I left them alone. Now it rides like it's on rails.
Oh Haha 08-08-2006 09:31 AM
Any light car will be affected by a semi passing. I think your issue is in the alignment.
My SC is setup pretty good and still gets moved by a semi's air stream.
Can you imagine what a Yugo driver goes through?;)(
71T 08-08-2006 09:50 AM
Check your ride height too. I had a similar problem and lowering it helped a lot.
450knotOffice 08-08-2006 09:54 AM
How old are your struts, shocks and Tie rods? If they're old, I'd spring for new ones and then have the car re-aligned by a reputable Porsche shop. That should take care of the problem.
(edit, whoops I forgot about the ball joints)
zachsbug 08-08-2006 10:08 AM
I have a 68 T that does not have the problem as you described. I replaced the bushings, tie rod ends, ball joints, struts, strut mount & added a strut brace & it handles fine. Check all the above.
