a little help with some torque specs?
torque spec for harmonic balancer...and locktite type and torque spec for flywheel bolts for a 964?
thanks
Old 08-10-2006, 10:50 AM
MBEngineering's Avatar
HI the crank pully to crankshaft is 235Nm(173ft-lb) held with tool No9290.
Flywheel to crankshaft (new bolts).
Single mass flywheel C4 90Nm (66ft-lb).
Double mass 85Nm (63ft-lb).
I do NOT put locktight on the flywheel bolts thread (have you tried to get a snaped flywheel bolt out of the end of the crank!!) a good torque wrench, oil the threads and of you must use lock- tight, put a little under the head of the bolt.
regards mike
Old 08-10-2006, 12:40 PM
ok thanks very much....
Old 08-10-2006, 12:56 PM
