-   -   start problem (http://forums.pelicanparts.com/porsche-911-technical-forum/29823-start-problem.html)
MMBRAZIL 03-17-2000 06:59 AM
start problem
The problem I´m having on hot starts is fuel abssence. Even with the hand throttle up the fuel takes a long time to reach the fuel distrib., and when it burns looks like comes with too much air and the misture stays like that for the hole ride. I already changed my fuel acumulator. Any ideas??
jryerson 03-17-2000 07:55 AM
Could be the check valve in your fuel pump,
Also try leaving the gas cap loose for a temp fix
MMBRAZIL 03-17-2000 10:51 AM
Tks, jryerson. But....
...is the check valve inside the pump?
How can I check if its the check valve and how do I fix it? Have to change pumps?
jryerson 03-17-2000 10:55 AM
The check valve is located on the pump wherethe fuel line connects it screws into the pump on some models its just before the pump maybe a few inches in the line
you can buy a check valve for about $20 so you don't need to replace the fuel pump
[This message has been edited by jryerson (edited 03-17-2000).]
MMBRAZIL 03-17-2000 11:33 AM
Tks....
