Low voltage at headlights
Hi everyone,
The problem is the low beams look like parker lights, and the high beams look like low beams.
The voltage at the fuse, and at the headlight is only 3 volts when on low beam. I didn't have a helper so couldn't check the voltage when hi beams are on.
battery is fully charged
Is this a relay problem?
Thanks for you help,
Adam
_____________________
'73 RSR Interpretation
Old 08-15-2006, 02:38 AM
Porsches.... unfortunately....don't have relays in this circuit as delivered from the factory. You are well advised to add them. There are plenty of posts on this subject...think "Marcus Sucro"...
I would first check overall system voltage...as measured between the battery terminals. Should be 12.6 volts for a fully-charged battery. Anything close to 12.0 Volts or less is essentially a dead battery. Do this first before you start checking branch circuits.
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 08-15-2006, 04:25 AM
yes..i already checked that. And it was 12.7v
And by the way, it is a ROW car with H4 headlights standard. Does it still not have a relay?
Old 08-15-2006, 04:32 AM
No !!...Porsche is incredibly stupid in this area....
Wil
Wil Ferch
Old 08-15-2006, 05:23 AM
You're likely getting a lot of contact resistance along the "way"...and the "path" may lead to badly pitted steering column switch, which carries ALL the electrical load. A relay would reduce this hundreds-fold as it would only be a "triggering" circuit instead....
- Wil
Wil Ferch
Old 08-15-2006, 05:25 AM
DW SD's Avatar
You can also use the Porsche standard round relays for headlights for a more stock look. (Rather than adding the non - standard sucro relays.) Wiring up the relays into the headlight harnesses at the fuse panel is how I did mine.
Doug
1971 RSR - interpretation
Old 08-15-2006, 07:02 AM
Early_S_Man's Avatar
Porsche Crest
Adam,
Sounds like a burnt stalk switch problem. Does the control stalk not switch the headlamps to the high beams when moved forward? It sounds like the 'Flash' position still works.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-15-2006, 07:58 AM
ruf-porsche's Avatar
Wil
It's not just PORSCHE, I think it a German Engineer thing. My Audi didn't have a fuse for the radiator fan, so when the fan froze up it took the entire front harness with it.
Old 08-15-2006, 03:15 PM
Originally posted by Early_S_Man
Adam,
Yes.. When i push the stalk forward to what would normally turn the high beams on permanantly, it doesn't work. But pulling back to flash works. Albeit not very bright
Old 08-15-2006, 05:56 PM
Dirty contact or pitted contact on the stalk switch, replace the stalk switch and install relay for the headlights
Old 08-15-2006, 06:13 PM
ok i will look into it.
Thanks for everybody's replies!
Old 08-15-2006, 07:36 PM
