Installing hard fuel lines on a 79Sc
I have sourced the steel lines to replace the soft fuel lines from the injectors to the fuel regulator,but the fittings are different.
the old soft lines use a banjo bolt in the top of the regulator and the steel lines use a straight connection into the regulator with a ferrule/compression fitting.
Are there threaded inserts for the fuel regulator that i can use to fit the steel lines?
Thanks in advance.
HB Kramer
(4 sneaks and 6 airheads): 79 911SC Coupe (sunroof delete)
(2 sneaks and 2 airheads): BMWS: R12GS(a) R90S, and some old British iron as well.
Old 08-12-2006, 10:20 AM
KNS KNS is online now
Bump for a reply. I was looking at doing this as well. I don't think there is a threaded-type of fitting at the FD. Anyone else?
Kurt
Old 08-12-2006, 10:58 AM
Scott R's Avatar
I have an extra set of the fittings since I'm EFI now, let me make sure I have all six and I'll PM you.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-12-2006, 11:07 AM
Scott you have pm .
bruce
HB Kramer
Old 08-15-2006, 07:26 AM
Scott R's Avatar
I did not get your PM, however these should be the guys I had to go dig them out of my CIS parts toybox:
You pay the shipping and they are yours! I'm EFI now so I am going to be getting rid of all of my CIS stuff.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-15-2006, 06:28 PM
Scott,
thanks much!!!!! appreciate your willingnss to help out. send me your address and i will get $10.00 in the mail
My cis is running fine what do you want for your spare cis? and is it operational Why do you go EFI? did it die? more HP ?
just curious thanks .
you can email me your address at hbkramer@aol.com or here if you like .
Thanks Again !
again.
HB Kramer
Old 08-15-2006, 07:28 PM
