| Registered Join Date: Jul 2000 Location: WV
				77' 911S bushing replacement help
			alright gentlemen, I am in the process of collecting all the necessary parts to replace the suspension bushings on my 77' 911S. I plan on starting w/ the front A arms and then working my way to the rear trailing arms and the spring plates. Is there anything special I need to do once I get the A arms, spring plates, & trailing arms off and am ready to reinstall. Do the torsion parts need to be "retimed" (or whatever you would call it) once the parts have been removed from the car. I try to do the majority of my repair work and am fairly confident I can do this job but if the torsion bars need anything special done to them during reassembly I may need to take it to an expert. any help would be greatly appreciated thanks in advance, Chris   | ||
|  08-13-2006, 11:57 AM |
			bump
|  08-19-2006, 10:25 PM |
| Registered Join Date: Feb 2006 Location: Westfield, New Jersey
			Easy.  I assume you have a manual so you know what parts to remove.  But you do know the info is already here on this board?  Here's the link for the fronts http://www.pelicanparts.com/techarticles/911_suspension_bushings/911_suspension_bushings_front2.htm  and these are for the rears http://www.pelicanparts.com/techarticles/911_suspension_bushings/911_suspension_bushings.htm   Good luck Allan
				__________________ 1971 911S, 1974 914 2.0, 1999 Boxster, 2003 Boxster, 2008 Cayman S. www.TheLolaRegistry.com "When you think you are in full control, you're just not going fast enough." | ||
|  08-19-2006, 10:39 PM |
