Danimal16's Avatar
Rear Spring Plate Cover, INFO needed
I need two of the covers for the rear torsion bar to spring plates. Or if anyone has the part number that would be great. (Not listed in PET) Photo of the arm with the plate missing.
Dan
Old 11-15-2018, 07:10 AM
Don’t think these are offered separately. But a member here had created a slick “boot” cover to give the same functionality. I hope someone chimes in with the details (I can’t easily search at the moment).
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 11-15-2018, 09:24 AM
bennysc1
I just had the same situation. I had to reach out to a salvage yard in CA that specializes in Porshe's and had the guy take them off a wrecked car. PET does not offer them. I have tried !!!
Old 11-15-2018, 04:23 PM
HarryD's Avatar
Or for that matter, go to you local hardware store and find a plastic or metal cap that fits.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-15-2018, 04:33 PM
Uncertifiable!!!
Uwon's Avatar
Electrical conduit plugs from Home Depot. They are tight so heat them up in real hot water first.
Cheers,
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 11-16-2018, 03:52 AM
Recently Disbanded
juanbenae's Avatar
you can also get the ones for the sway away adjustable spring plates. I found them at auto atlanta or the Porsche place that is named close to that. I ordered 4 and keep the two extras in a parts box.
Old 11-16-2018, 07:55 AM
1QuickS's Avatar
Actually, I believe the OEM plugs were metal & were staked in place to keep torsion bars from working out. You can see the stake marks around the perimeter of the recess in the photo of the first post.
Perhaps you could measure the diameter of the recess & then buy freeze plugs from your local auto parts store.
I did not bother with caps or plugs on my car.
Old 11-16-2018, 09:24 AM
Danimal16's Avatar
I am checking on some replacement sources based upon the advice here. The diameter is about 37.85 MM.
Dan
Old 11-16-2018, 09:59 AM
1QuickS's Avatar
Check them out here:
https://www.lawsonproducts.com/lawson/Expansion-Plug/3059.lp
Old 11-16-2018, 10:54 AM
Odd that you can buy them for the front but not the rear.
1982 911 Targa, 3.0L ROW with Webers
Old 11-16-2018, 11:04 AM
Danimal16's Avatar
Thanks for the link.
Dan
Old 11-16-2018, 11:19 AM
