-   -   Turbo O2 sensor position (http://forums.pelicanparts.com/porsche-911-technical-forum/298651-turbo-o2-sensor-position.html)
edbaus 08-14-2006 10:04 AM
Hi,
I have a race 911 turbo. I have a zork tube for an exhaust. The question I have is where should the o2 sensor be mounted. Before or after the turbo. And if one or the other, how far from the turbo or outlet pipes.
Ed
fredmeister 08-14-2006 12:11 PM
You should try to keep it after the collector for at least 3 exhaust pipes, but before the turbo so that it is real hot. The O2 sensor needs to be above 600 degrees to function properly.
fredmeister 08-14-2006 12:12 PM
How much power increase did yousee by adding just the zork tube versus the muffler?
Thanks,
Fred
edbaus 08-14-2006 12:46 PM
This motor was built ground up for road racing, so it never had anything but the zork.
Ed
YermanCars 08-14-2006 01:42 PM
after the turbo 6-12 inches.
