engine bay rust
Hi all, a newbie here...
Take a look at this engine bay picture. I see what appears to me to be rust on the back wall of the engine bay. Is this a cause for concern? What if the rest of the car turns up rust free? Is the rust in the engine bay a deal breaker? Thanks for any advice you can give me. http://forums.pelicanparts.com/uploa...1155586586.jpg |
Glue from sound pad that is missing. Don't worry.
What you think is rust may just be the adhesive residue from a missing engine pad - mine looks the same way. You can check this by trying to clean it off with a solvent like lacquer thinner. They sell replacement pads on this site or you can fab one yourself using a variety of materials- there are a lot of threads on this issue, just search 'engine pad' on the 911 tech forum.
I agree just that crappy glue.
Ok thanks guys... so my newbie follow-up questions would be...
1. what function does the engine pad serve? 2. do I need it or do I need to be concerned that this car doesn't have it? I appreciate the help. |
The main purpose of the engine pad is to lower the sound level in the car's interior that is generated by the engine running.
I would replace it at the first engine drop, but not until then. You can only replace it while the engine is out. -Matt |
It makes the engine slightly less noisy, but only below 5000 rpm. Let it sing!
With no disrespect intended if you can't answer those questions you should not be considering buying a 911 off eBay. Do a search on PPI's and eBay purchases. Or just tell me to mind my own business. :)
| All times are GMT -8. The time now is 04:01 AM. |
