Rennch on YouTube
How useless is the passenger side mirror on the 69 911?
Seriously...I can't even see it when I'm sitting in the driver's seat. It's completely obscured by the A Pillar and the window frame. Bad design?
Any tricks, or should I replace it with another mirror?
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
that's because you used the oe holes in the door matching the driver side , right?
so yes it is now basically useless for install examples go look at any 911 SC or carrera with power mirrors- you will see where they placed the passenger side mirror
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
There have been a few threads previously about the fact that the passenger mirror is in a different location - it is mounted more to the rear. You'll have to do a search to get all the correct dimensions, but here is one that came up:
Long arm Durant...
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
yes different location than OE pre drilled holes which were there for RHD, factory installed second mirror was farther back and the actual mirror was more convex than driver mirror (durant mirror). I believe there is an actual factory location for that mirror that you can find on the door, it is referred to as a divot or indentation under the door skin.
Member #750 Early911S Registry 1970 911E I know Where Jerry S. has his NYC Garage Yadda Yadda Yadda Last edited by boxster03; 08-15-2006 at 06:09 PM.. |
