-   -   Warm start problem and rough idle. (http://forums.pelicanparts.com/porsche-911-technical-forum/298830-warm-start-problem-rough-idle.html)
nixter 08-15-2006 11:45 AM
Hi all, some of you may remember that I had an '80 Euro CIS fitted to my '80 US SC. The difference is awsome! so much better than before. gobs more power. I suspect the original setup was fouled so I wasn't getting full power out of it to begin with though.
Anyways, having a problem with warm starts. (starting cold is flawless) When I attempt to start the car warm it will take 2 or 3 tries before it starts. Even when it finally fires it idles very poorly and I must apply throttle to keep her alive for 20 seconds or so. After that all is fine again.
Any takers?
Cheers,
nik
Al S 08-15-2006 12:47 PM
Nik,
Usual culprits are fuel accumulator or check valve at fuel pump.
Check your residual fuel pressure.
Good luck!
Al S
