Warm start problem and rough idle.
Hi all, some of you may remember that I had an '80 Euro CIS fitted to my '80 US SC. The difference is awsome! so much better than before. gobs more power. I suspect the original setup was fouled so I wasn't getting full power out of it to begin with though.
Anyways, having a problem with warm starts. (starting cold is flawless) When I attempt to start the car warm it will take 2 or 3 tries before it starts. Even when it finally fires it idles very poorly and I must apply throttle to keep her alive for 20 seconds or so. After that all is fine again. Any takers? Cheers, nik
1980 911 SC widebody, Black/Black. 1993 BMW M5. Silver/Black. |
Nik,
Usual culprits are fuel accumulator or check valve at fuel pump. Check your residual fuel pressure. Good luck! Al S
Al Shkuratoff 86 Carrera, SW chip, Fabspeed, M&K 83SC Platinum - Sold 83SC Slate Grey - Sold |
