DCOP's Avatar
Pics of rear sway bar needed
My 70 has a front sway bar which looks stock? However the rear doesn't have one? I'm trying to figure out where the mounting holes are if any, to see if it was removed for some reason. Were sway bars a factory option for a 1970T? Any pictures of the rear bar and mounting points would be helpful. I would like to install a new rear bar but not sure where to start? Thanks!
70-911T/ RS Tribute 2.7
Old 08-15-2006, 04:45 PM
Administrator
Jack Olsen's Avatar
Most likely, your rear mounts cracked and -- if you don't see anything there now -- a previous owner cut the mounts off.
Wevo makes some awesome replacement mounts.
Old 08-15-2006, 05:42 PM
i hate to disagree with an icon, but...
my 72 T, for example, did not come with a rear swaybar. consequently, there were no rear mounts. if the wevo's price makes your heart skip a beat, the regular ones should do you for a while.
you will have to weld mounts onto the car, unless you want to use the weltmeister U-bolt setup.
Matt
72 911T Targa - Sold
Hang up the cell phone. Put down the Latte. Ignore the kids in the back seat.
Use your blinker when you want to change lanes. AND DRIVE YOUR Fu@#!NG CAR!!
Old 08-15-2006, 06:18 PM
HarryD's Avatar
If you do not have the factory mount, you can always go the "Weltmeister way" of the u-bolt over the torsion bar tube and the bar ends connected the the springplate eccentrics.
I did that in my '73 and it works just fine. Some details here: adjustable sway bars...1971 chassis
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 08-15-2006, 06:25 PM
randywebb's Avatar
IF you bleieve that these cars should live forever, then you can amortize the cost of the Wevo over infinity...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 08-15-2006, 10:04 PM
Infinity (and beyond) is good only if you're around to enjoy it.
My '69 911T didn't have a front or rear sway bar when I got it. It had 5.5 x 15 wheels on 165-15 tires and handled like a sissy. It's a little better now.
Sherwood
Old 08-16-2006, 02:09 AM
randywebb's Avatar
Don't tell people that Sherwood! I might want to buy their car after they fix it up...
Old 08-16-2006, 11:17 AM
