Turn Signal Malfunction in SC
I'm tooting down the road the other day going to a Porsche dealer, and all of a sudden my turn signal stalk stopped working--no clicking sound and no flashing arrows on moving the stalk up or down.. A few minutes later, everything's working normal again. The mechanic checked it briefly at the dealer, and found nothing.
I'm wondering if somehow the stalk had jammed--and then unjammed itself. Hopefully, it isn't electrical.
'03 Boxster *****
'82 911SC ****
'98 BMW Z3 **
'87 300Z ***
'80 BMW 320i ****
Old 08-18-2006, 07:07 AM
Doug&Julie's Avatar
Most of my past turn signal problems were relay related...could that be the case here?
Doug
Currently Between Porsches
PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944
Old 08-18-2006, 07:25 AM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
I've had to replace this switch twicw in 25 years of owning my 911. Another symptom is the high beam flasher creeps on and off.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 08-18-2006, 07:44 AM
When these switches act up, IMO, I'd just rather replace with a new one from our host. Pretty simple DIY project.
Tony G
2000 Boxster S
Old 08-18-2006, 08:09 AM
'03 Boxster *****
'82 911SC ****
'98 BMW Z3 **
'87 300Z ***
'80 BMW 320i ****
Old 08-18-2006, 08:45 AM
kwm kwm is offline
Mine used to do that due to grounding issues in the circuit.
83SC black on black
01 Chevy S10
08 Buick Enclave
Old 08-18-2006, 09:17 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Mind did that the other day along with other minor electrical gremlins. Turned out to simply be corrosion around some of the fuses. First I cleaned then simply replaced all the fuses and the difference is unbelievable.
Chris
73 911 E
Old 08-18-2006, 11:00 AM
moderator: we seemed to have lost two posts in this thread about signal switches. thanks.
'03 Boxster *****
'82 911SC ****
'98 BMW Z3 **
'87 300Z ***
'80 BMW 320i ****
Old 08-19-2006, 07:18 AM
ruf-porsche's Avatar
Posters might had deleted the posts themselves
Old 08-19-2006, 08:25 AM
Just came back from a drive this morning, and turn signal was normal--as it was yesterday also.
I think the stalk may have gotten jammed briefly last week--there is some play in it, and you have to turn it without too much pressure at the right angle --parallal to the steering wheel.
After driving this morning, in the garage there were the usual cooldown noises--of hot metal joints cooling, etc. A new one--a faint buzzing somewhere under the front hood, which stopped when I depressed the hood a bit--and went away after a few minutes. Always a new experience with these cars. But a happy 911 owner is one without oil leaks. Dry as a bone.
'03 Boxster *****
'82 911SC ****
'98 BMW Z3 **
'87 300Z ***
'80 BMW 320i ****
Old 08-20-2006, 09:03 AM
Moke81's Avatar
I was battling this problem for a while, turned out to be the plug and the flasher unit. When I firmly push together they would work when I release they would stop. The solution for me was to use a large hose clamp and tighten down on the unit, problem solved.
Old 08-20-2006, 09:06 AM
Bill Verburg's Avatar
For thoose of you that may be confused, I merged the 2 turnsignal threads
Bill Verburg
Old 08-20-2006, 10:31 AM
jaydubya's Avatar
I had this same problem. The male connectors on the flasher were intermittently coming out of contact with the female connectors in the rubber plug. Only happened when it was hot - very frustrating.
I fixed this permanently by gently bending the male connectors outward on the flasher so that they made better contact with the female connectors in the plug.
'82 911SC racecar
'05 WRX STi
Old 08-20-2006, 10:45 AM
