Need help with ajusa cool brake kit install
How the heck do you get the hoses over the rotor base and the air scoop? I can't get them even close. Seems like the diameter of the metal rings in the hose is much smaller the diameter of attachment point. Can I pull the metal rings out and just attach the cloth with the clamps?
Sean 1982 SC D-Stock #372 NASA GTS2 1971T restoration in progress, read about it here: http://911restorationmadness.blogspot.com/ |
Sean,
I would say the metal rings are embedded in the high heat tubing for the ducts. Double check the measurements. If I recall correctly, the AJ duct inlet is oval so you have to really muscle the duct tubing. Might try a little (very little) lube on the duct ends. Make sure you put the clamps on first so you don't have to remove the hose again. (don't ask!)
Tony G 2000 Boxster S |
Good point about the clamps, I would have screwed that up and that would have sucked. I just can't get the darn things on. Maybe I need more muscle
Southern Class & Sass
I just shot the ducts with some soapy water. A few cuss words later they were on.
Dixie Bradenton, FL 2013 Camaro ZL1 |
Are you sure you have the right diameter hose? Did it come with the kit?
'82 911SC racecar '05 WRX STi |
Thanks guys...I got it finally. The trick was to separate some of the wire from the tubing in order to pull it over the cylinder. It was a PITA.
