Bolt for Transmission broke off???
1978 911 sc
both transmission bolts are broke off leaving the transmission laying on the rear sway bar.....bolts broke about half way dont know how long it has been this way car bought last week anytips on removing and replacing or mabye putting a tru-bolt in any tips would be a big help would love to get it drivable again thanks for your time -dan |
Drill and easy out and welcome to the board
Are you talking about the two larger bolts on either end of the trans mount?
If so, they are easily replaced but you will need to extract what's left. Maybe throw some pictures up for us. It's really isn't that big of a problem. Where are you located? There's probably a Pelican in the neighborhood.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
thanks for the fast input im running back and forth with my father in the garage with the updates
ok it is the 2 larger transmission bolts that go tru the mounting bracket and up into the frame we found both bolts to be missing after we were having problems with the transmisson bucking and popping out of gear we were surprized to find what we did we are concerned that the bolts might b rusted in so we dont want to rush it we want to make sure we do it right and the easy way we are located in Peoria IL and got the car as a father son and son project and so far im having a blast this website and thread is great i appreciate all the help |
Get a light and see if the bolts are indeed broken off. If they are just missing you can get replacements. Grade 8 hardware can be found at most large hardware stores or automotive suppliers. WE just need to figure out the specs. I don't know that right now.
You'll want to jack the engine/trans assembly up to get it back into the general mounting area. Right now, there is a lot of stress on the rear mounting points at the engine. It should only need be raised a couple of inches. I would suggest taking the trans mount off of the trans itself. There are four bolts that attach it to the trans.
we got replacment bolts and washers and they only thread in a couple of turns we got a mirror and looked up to find part of the bolt still in there...
we jacked up the tranny to take off the stress but if you raise it more than an inch or 2 the hole do not line up but first we need to get the remains of the old bolt out
--Dan -=1978 911sc targa=- -=1980 911sc widebody conv=- -=2009 Carrera =- |
As nostatic would say where the pictures? Newbie needs to post pictures of their car on this site. Last edited by ruf-porsche; 08-22-2006 at 07:29 PM.. |
well if photos r a must here she is in all of her glory at the beging of the project
sorry 2 small
Nice Bimmer and the PORSCHE ain't too bad either
well its all done thanxs for all the help its drives and shift 100% better!
Sweet!
I had to get to sleep but I see you finshed up. Nice job. Car(s) looks nice, too.
Irrationally exuberant
I've seen a lot of those bolt holes stripped out. Even stripped out some myself.
A TimeSert will fix them properly.-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Formerly bb80sc
I'd also check the rear bolts, motor mounts and mounting crossbar. That 'hanging' tranny could have fatigued those parts as well. Good luck, and welcome! Sounds like a cool project.
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
