8:31 to 7:31
Hello,
I want to change my R&P from an 84 915 euro (8:31) to a 7:31.
How many hours it may take in a Porsche only shop ???
Also what is a fair price for a 7:31 r&p ???
8:31s has so if any value also ???
Thanks!
Old 08-18-2006, 04:42 PM
Bill Verburg's Avatar
Why?
Bill Verburg
Old 08-18-2006, 04:56 PM
typ 911
Bryan Beaumont's Avatar
Porsche Crest
Why??? Are you kidding? If so, I do not get it.
Perhaps you can simply think about your question of "why" for maybe
20 seconds and come up with some of the many possible answers.
Disappointing that you would lob out your comment, which is nothing
more than a meaningless negative jab.
Bill, thanks for your many contributions to this board, but WHY....did you see the need to respond in this way? You are generally a huge asset to this board, not to mention a moderator. I guess I just was surprised that that post came from you. Are you having a bad day? If so, I hope your weekend is better.
Bryan
'74 911-Not Stock...
typ911@gmail.com
Old 08-18-2006, 06:13 PM
Bryan,
Sorry, but Bill's question is legitimate. Essentially Bill is asking Jim what are his expectations.
There is an up and down side to this type of change.
Jim,
I switched complete transaxles for the following reason:
A decent 7:31 ring and pinion will cost $500. Set up in your or my trans will run 5 to 10 hours labor, not counting removal and replacement.
These days that is $300 to $600 just for setup labor.
I bought a nice '72 trans with a 7:31 for $1500.
If I'm still happy, my '76 trans will be for sale $1200, no issues.
Net cost to me $300 vs $800 to $1,100.
What is your reason for the switch?
Guy's like Bill are very knowledgable about these things.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 08-18-2006, 11:27 PM
Well,
I think that with the 7:31 the engine will rev more easily and the decrease in top speed is not an issue for me...
Thanks!
Old 08-19-2006, 12:40 AM
Here is what a 915/67 looks like stock
For Autobahn use it is nicely set up.
for sporting use the issue, which is what I think you are concerned about, is the spread from 3rd to 4th and 5th
here is what a change to 7:31 does
The max speed in each gear is decreased by ~15% but the primary issue of awkward spreads has not been addressed.
here is a better(IMO) solution short 4,5
this can be juggled a bit, say a little longer on 5, or a more expensive 3,4,5 change.
This has the advantage of closing up the top, where you need it, but not compomising the spread or strength of the bottom, or the strength of the cwp
Bill Verburg
Old 08-19-2006, 03:22 AM
beamonk's Avatar
Send a message via AIM to beamonk
I have it in my 3.0 euro SC. I don't particulary care for it. It doesn't seem quicker than the old 8:31.
John Brasfield
91 C2
78 SC For sale
76 3.6
68 Datsun 2000 Mr. Magoo, 02 330ci
Old 08-19-2006, 05:57 AM
jaydubya's Avatar
Great info here!
Bill, I imagine that changing tire diameter just scales the numbers?
The reason I ask is that race tire sizes are always forcing me to deal with an increase in diameter with an increase in width on my '82 SC. In Hoosiers I can either run a rear with size 245-45-16 (or 245-40-17) with a diameter of 24.4" (24.5"), or if I go wider in the rear I can run a 275-45-16 (or 275-40-17) with a diameter of 25.3" (25.2"). It would be useful to see exactly how the differences affect gearing.
Most people that I ask say that in terms of lap times it's better to run the smaller diameter tire even though it has a smaller contact patch (you can generally lower the car more, better gearing, somewhat less rotating mass). I guess it depends on the particular track too.
Are these data coming from an Excel spreadsheet? If so, perhaps I could get a copy to play with?
For PCA club racing, changing R&P or gears bumps you up at least one class.
Cheers,
Jeff
'82 911SC racecar
'05 WRX STi
Old 08-19-2006, 06:07 AM
Yes, It does exactly what changing the cwp does, only less so.
to calculate what a different diameter tire does you need to know the % difference in increase or decrease of the dynamic loaded radius from your base tire is as a decimal then just multiply.
Bill Verburg
Old 08-20-2006, 10:48 AM
jaydubya's Avatar
^^^ Thanks!
Cheers,
Jeff
'82 911SC racecar
'05 WRX STi
Old 08-20-2006, 10:56 AM
Bill,
way to bring the info despite the flame... I tip my hat...
Old 08-20-2006, 05:55 PM
GrantG's Avatar
I've heard that the 8:31 is significantly more stout for those who track their cars more frequently (7:31 can crack for those who are unfortunate or stress the box alot). I think the best option (though not cheapest) is to keep the 8:31 and change the gear stack making the ratios closer together.
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 08-20-2006, 06:09 PM
Amen, to that advice,....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-20-2006, 06:25 PM
This question came up in a PM, paraphrased, Is a shorter lighter tire better on track than a taller wider tire?
It's related to Jeff's ?
If you look at the thrust curves for a US Carrera w/ 2 different tires you can see what happens.
The taller tire will provide slightly less thrust but the main thing is that the speed where thrust peaks is moved up(to the right), In a drag race 0-whatever it is most important to get the max thrust as soon as possible, but on track as long as you aren't shifting in a corner it is more important to carry a higher speed through the corner.
Bill Verburg
Old 08-21-2006, 04:16 AM
Also note that in a drag race it's the lower and middle gears being used, on track it's the middle and uppper gears where the thrust difference is less.
Bill Verburg
Old 08-21-2006, 04:19 AM
