-   -   idling problem (http://forums.pelicanparts.com/porsche-911-technical-forum/299780-idling-problem.html)
JINKATIN 08-20-2006 09:30 PM
idling problem
I have an 86 carrera when it hits operating temp. It accelerates on its own, when I press or release the clutch it will accelerate for a couple of seconds. I thought it was the floor mat push up against the gas pedal, but it still does it.
Any thoughts?
Thanks,
jinkatin
jester911 08-21-2006 03:40 AM
Are you saying fluctuating idle or engine revs up like the throttle is stuck?
If fluctuating it could be many things but I would check the cylinder head temp sensor.
I just replaced mine after chasing a idle problem for some time.
ruf-porsche 08-21-2006 10:22 AM
You need to rebuild the pedal assembly with new bushings.
JINKATIN 08-21-2006 01:18 PM
Revs up. Yes, that's the word i could not think of.
Thanks you guys I do appreciate it.
jinkatin
