-   -   top end rebuild 3.2 (http://forums.pelicanparts.com/porsche-911-technical-forum/300103-top-end-rebuild-3-2-a.html)
Shelton 08-22-2006 01:57 PM
top end rebuild 3.2
Just wondering , was quoted 3,500 to do top end on 86 3.2 was expecting to pay a lot more. This is to replace valve guides, seats stem seals and flywheel sensor, polish and port heads. Does this sound unreal or what, and yes shop does a lot of porsche work.
dtw 08-22-2006 02:01 PM
Sounds about right, especially if their labor rate is reasonable. What's the shop rate?
Shelton 08-22-2006 02:06 PM
65.00 per hour
Rot 911 08-22-2006 02:22 PM
Sounds about right.
jester911 08-22-2006 02:50 PM
Shelton,
just in case I may need to do this in the future, what shop is it, if you don't mind me asking?
JeremyD 08-23-2006 07:10 AM
That's what my mechanic quoted - The problem with quotes like this - is the while you are in there. yes $3500 for the top end.
But if you have the engine out in a 3.2 = you should really look at replacing the CHT and reference sensors and you should replace the infamous carrera fuel line at a minimum (unless they have been replaced recently)
