-   -   adding small gauge to a tach (http://forums.pelicanparts.com/porsche-911-technical-forum/300262-adding-small-gauge-tach.html)
randywebb 08-23-2006 12:04 PM
There have been several examples posted where a small gauge was added to a tach. In the Oct. Excellence (photo legend on p. 103) it says that the gauge was added to a 930 tach after the boost gauge was removed.
Is that what most people have done to add a gauge to a tach?
Does it seem like a fairly cheap DIY way to do this?
304065 08-23-2006 12:36 PM
The real problem is not drilling three small holes in the tach face to install the additional movement. It's getting the scale on the face (the usual suspects use a silkscreen process) and getting the bezel ring on and off without making it look like the dog chewed on it.
masraum 08-23-2006 01:05 PM
I believe you can buy the tach/voltmeter combo. What combo are you thinking about?
TRE Cup 08-23-2006 01:18 PM
no ho speedometer has done several different combos for us using the 930 tach idea- clock, voltmeter, a/f ratio led bar readout. you may want to contact them directly
Jim Richards 08-23-2006 01:29 PM
check this thread out...
http://forums.pelicanparts.com/porsche-911-technical-forum/237637-photoshop-tach-advice-help-needed.html
randywebb 08-23-2006 01:55 PM
Dunno. As usual, I'm just noodling around before trying anything. I have an idea to put the older (green) gauges into my '73, but a volmeter in the stock tach is also interesting -- or a vacuum gauge; or twin cyl. head temp gauges like RoninLB has on his dash or console.
masraum 08-23-2006 02:35 PM
Of course North Hollywood could do the tach/other combo in the traditional green for you as well as re-indexing the tach needle to put the redline at the top.
304065 08-23-2006 03:28 PM
Randy, if you want green gauges the best thing to do is have one of the usual suspects re-silkscreen the faces of your current gauges:
Tach-- will not work with CDI ignition as it requires a HV pulse from coil
Speed- may not read the same from a 915 as a 901
Clock- later versions are Quartz, not mechanical/battery
Oil pressure, temperature resistance changed in 1968, sender different
Fuel-- don't know whether fuel tank capacity increased to 65L?
randywebb 08-23-2006 04:05 PM
Thanks John - I do have a type 911 trans. tho.
