adding small gauge to a tach
There have been several examples posted where a small gauge was added to a tach. In the Oct. Excellence (photo legend on p. 103) it says that the gauge was added to a 930 tach after the boost gauge was removed.
Is that what most people have done to add a gauge to a tach? Does it seem like a fairly cheap DIY way to do this?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
The real problem is not drilling three small holes in the tach face to install the additional movement. It's getting the scale on the face (the usual suspects use a silkscreen process) and getting the bezel ring on and off without making it look like the dog chewed on it.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
I believe you can buy the tach/voltmeter combo. What combo are you thinking about?
no ho speedometer has done several different combos for us using the 930 tach idea- clock, voltmeter, a/f ratio led bar readout. you may want to contact them directly
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
Bandwidth AbUser
check this thread out...
Photoshop, Tach advice/help needed
Jim R. |
Of course North Hollywood could do the tach/other combo in the traditional green for you as well as re-indexing the tach needle to put the redline at the top.
Randy, if you want green gauges the best thing to do is have one of the usual suspects re-silkscreen the faces of your current gauges:
Tach-- will not work with CDI ignition as it requires a HV pulse from coil Speed- may not read the same from a 915 as a 901 Clock- later versions are Quartz, not mechanical/battery Oil pressure, temperature resistance changed in 1968, sender different Fuel-- don't know whether fuel tank capacity increased to 65L?
Thanks John - I do have a type 911 trans. tho.
