-   -   Gear ratio vs speed calculation help (http://forums.pelicanparts.com/porsche-911-technical-forum/300446-gear-ratio-vs-speed-calculation-help.html)
jhhaas 08-24-2006 12:39 PM
Assuming a 915 with a 7/31 ring and pinion and a 26/26 5th gear running 335/30/18 rear tires, what would the wheel speed be at 7000 rpms?
Thanks in advance.
Huh 08-24-2006 12:59 PM
try this calculator:
http://www.scirocco.org/gears/
imcarthur 08-24-2006 01:14 PM
Just type your numbers in:
Transmission Calculator
Ian
Bill Verburg 08-25-2006 02:13 PM
I prefer to go back to first princpals and do the calc myself. You can get a more accurate result by inputting the actual dynamic loaded radius rather than the static unloaded radius that most of the calculators use.
The dynamic loaded diameter of a 335/30x18 tire is 25.1 - 25.4" depending on the tire
the formula is
MPH = (RPM*DLR*0.002975)/(TR*DR)
RPM - revolutions per minute
DLR - dynamic loaded diameter
TR - transmission ratio
DR - differential ratio
For your example, using an average of 25.25" for DLR
MPH = ~119mph
