jhhaas's Avatar
Gear ratio vs speed calculation help
Assuming a 915 with a 7/31 ring and pinion and a 26/26 5th gear running 335/30/18 rear tires, what would the wheel speed be at 7000 rpms?
Thanks in advance.
John H
2001 996 GT3 Cup
1969 911T
2015 Cayman GTS
Old 08-24-2006, 01:39 PM
Huh Huh is offline
try this calculator:
http://www.scirocco.org/gears/
'94 VW Jetta
'85 VW Scirocco
'81 911 SC coupe Euro
'67 VW Bug
Old 08-24-2006, 01:59 PM
Used Up User
imcarthur's Avatar
Just type your numbers in:
Transmission Calculator
Ian
'87 Carrera Cab
Old 08-24-2006, 02:14 PM
Bill Verburg's Avatar
I prefer to go back to first princpals and do the calc myself. You can get a more accurate result by inputting the actual dynamic loaded radius rather than the static unloaded radius that most of the calculators use.
The dynamic loaded diameter of a 335/30x18 tire is 25.1 - 25.4" depending on the tire
the formula is
MPH = (RPM*DLR*0.002975)/(TR*DR)
RPM - revolutions per minute
DLR - dynamic loaded diameter
TR - transmission ratio
DR - differential ratio
For your example, using an average of 25.25" for DLR
MPH = ~119mph
Bill Verburg
Old 08-25-2006, 03:13 PM
