Engine compartment light, where?
Where do you install the engine compartment light?
Can somebody post a picture of this light installed?
Also, the hot wire is always hot or should be switched?
In case of switched, in what circuit (marker lights?) should I connect it?
you
Old 08-26-2006, 06:19 PM
slodave's Avatar
Hi!
Maybe this will help. Can't help you with the wiring.
Dave
Old 08-26-2006, 07:08 PM
Slodave,
Thanks for the picture.
Probably if you can answer these questions I can figure out how it is connected.
The light can be turned on just by opening the chrome window when:
1.- Markers light on
2.- Nothing on
Thanks again.
Old 08-26-2006, 07:25 PM
slodave's Avatar
The light in my car has not worked for a few years. I don't remember if it was switched or not. My car is also not with me at the moment, so I can't even test the socket for you. Sorry.
Dave
Old 08-26-2006, 07:29 PM
Dave,
Thanks.
Hope somebody will have an asnwer for me.
Old 08-26-2006, 07:55 PM
47silver's Avatar
light
hi
doodled this for you
1975 911S Targa
Silver Anniversary Edition
Old 08-26-2006, 08:21 PM
buttjoint's Avatar
Headlights have to be on!
Old 08-26-2006, 08:25 PM
47silver,
thanks, but that is not what I was asking. I know how to connect a light. This particular light fixture has a switch in the assembly, when you open the chrome part the light turns on.
What I need to know is, if the light fixture is connected to an always live circuit or if it is connected to a switched marker light circuit.
Old 08-26-2006, 10:04 PM
