ruf-porsche's Avatar
Need to replace hood shock
Replaced the hood shock on the passenger side, but the driver side in addition to having a lot of cables it also have the connection for the hose from the gasoline filler to the gasoline tank. Any tricks or secrets to replacing the shock?
Old 08-26-2006, 05:57 PM
LakeCleElum's Avatar
I used a long pair of Dental type forcips (spelling?)......Do a search here, several good tips available......
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 08-26-2006, 06:24 PM
azporsche911.com
Hoffmanmotors's Avatar
It took me like 2 minutes to do the passenger side, and 45 min to do the driver side, kept droping the dang clip in the wiring mess. I ended up using a long thin flat head screw driver and jammed the clip on the tip and managed to shove it on to the pin.
Old 08-26-2006, 06:58 PM
My former involvement in the Drug Culture paid off handsomely in the process of changing the driver's side strut. My roach clip from a previous life, a pair of hemostats, made short work of the clip and the pin in the jumble of wires.
I knew I kept those things for a reason.
Dave
1969 911T Coupe
1972 911E Targa
Old 08-26-2006, 08:05 PM
MIK911's Avatar
ZIP TIE !
To remove old shock:
I used a small zip tie threaded thru the circlip (with one hand). Partially close the zip tie (to create a loop). Now you've got leverage to pull on the zip tie/circlip which releases it from the mounting rod/hood shock base.
To mount new shock:
Tie dental floss or string to zip tie/circlip (so when you drop it, easily retrieved). Put small amount of grease on circlip where it must slide past the mounting rod. Now you can use one arm to clip the circlip onto mounting rod/hood shock.
Once mounted, wire cutters used to cut zip tie for disposal.
Lastly, a telescopic rod with magnet came in handie retrieving small pieces, like the small mounting rod that the circlip clips to.
I used this method to change all 4 (F and R) of my shocks, and it went smoothly.
good luck
Mike
'86 911 coupe
'85 BMW 535i
'11 Cayenne
Old 08-26-2006, 10:47 PM
mkimber's Avatar
Replaced my hood shocks a couple of months ago. Here's the thread on it.
Replaced MY Front Hood Struts Today
Michael
1987 3.2 Carmine Red Carrera
1995 Midnight Blue 993 C4
1957 Silver Speedster Outlaw (replica)
Old 08-27-2006, 02:03 AM
cameron.arnott's Avatar
Small hands are a big help!
Know any kids??!!
'74 RS 3.0 Replica
Porsche 968 Clubsport SOLD
'70 911E Bahia Red SOLD
'71 911 S/T Replica 2.3 Twin plug BEAST SOLD
Old 08-27-2006, 02:21 AM
Bird. It's the word...
Fishcop's Avatar
I went with the Seine Systems carbon prop... very functional and you'll never have to replace the shocks again
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 08-27-2006, 02:35 AM
Know any kids??!!
I have a four year old and a two year old, they have small hands, but they don't understand instructions very well.
Old 08-27-2006, 04:20 AM
safe's Avatar
Women usually has smaller hands, maybe a girlfriend of wife?
I did it some years ago, no special tools what I remember, but I have long fingers and it took a long time.
I think I put the clip on the other side of the shock, I reached thar side easier.
Magnus
Old 08-27-2006, 02:02 PM
There is so much "pre-load" on the pin that you don't need the circlip at all on the driver's side........it'll never come out by itself....
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 08-27-2006, 05:44 PM
Danny_Ocean's Avatar
Not to hi-jack this thread, but how the heck do you reach the inner part of the REAR strut? That sucker is about 4' inside the engine compartment...
Old 08-27-2006, 05:49 PM
I'm in the process of replacing all the hood and trunk shocks on my 82SC. The rear was a piece of cake. The passenger side was also easy, but it the driver side that looks as though it one of those PITA job.
My wife has small fingers, but to get dirt under them are you kidding.
I don't think it a good idea to have the girlfriend come over to our house and work on the PORSCHE.
LOL
Old 08-27-2006, 05:54 PM
randywebb's Avatar
yes - hemostats - maybe bent ones -- will help with pin and circlip
be sure to push the top part up into the sheet metal cage and leave it loose before you try to put the pin in the bottom
I put it in from the outside - with the holes pointing into the trunk interior
push the damn hoses and wire bundels out of the way -- more stooopid engineering design here.
use a small flashlight and a trouble light to get some light down there
it took me about 10-15 minutes on the drivers's side yesterday-- but I've done it before
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 08-27-2006, 05:59 PM
Goth's Avatar
Had same list of problems...
Ended up I using the clips for the 1989-94 year Carrera 2/4. Pelican part #: N-012-645-2-OEM.
Much easier to install & less than a buck!
Doug
84 Carrera Coupe - Black (the Goth look)
The more I learn, the more I realize I don't know
Old 08-27-2006, 06:56 PM
Less than a buck but I bet it cost more than a buck for the shipping.
Old 08-27-2006, 07:17 PM
Goth's Avatar
Yup! Only cheap if your going to buy something anyway...
Doug
Old 08-27-2006, 08:36 PM
anthony's Avatar
After screwing around with the driver's side strut for half an hour I lost the clip down in all the hoses so I just put a piece of duct tape around the pin to hold it in place.
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 08-27-2006, 08:46 PM
Originally posted by anthony
...so I just put a piece of duct tape around the pin to hold it in place.
Hey...are you the guy who used to own my car? Duct & electrical tape everywhere
Old 08-27-2006, 09:40 PM
randywebb's Avatar
oh yeh - keep a flex-magnet nearby when doing this ...
Old 08-27-2006, 10:27 PM
