der Mond's Avatar
Exclamation Please help with brake line removal
I got the left front caliper off OK, but when attempting removal of the hard steel lines from the rubber brake line to replace the rubber one, the nut will come loose from the rubber line fitting and will rotate free from its own steel line about 15-20 degrees rotation, then binds on the steel line, both at the strut end and up in the wheel well. I twisted the short lower line end somewhat, but it seems OK. I used a lot of PB Blaster and jimmied the nuts back and forth many times, but they don’t seem to loosen further. I have searched many posts on brake line removal and have heard of using everything from a Dremel tool (wouldn’t that destroy the hard line?) to Tabasco sauce. If I could just bend the short lower line until straight enough, I could unscrew it as is. If I did that and then bent it back after reinstallation, would that destroy it? If the hard line nuts didn’t have to come off first before removing the spring clips, I suppose I could just free the lines from the strut attachment point in order to give the lower line enough room away from the hub to rotate the whole line, cut the rubber lines and screw the new one in. But that doesn’t seem possible. Why does the line come loose from the caliper just fine but the other nuts don’t? How do professional mechanics replace these lines without destroying what I’m told are practically irreplaceable hard lines? Might a propane torch help? If there are any success stories out there, I could sure use one.
Peace & Thanks,
der Mond
'87 Carrera Coupe
Venetian Blue Metallic
Old 08-19-2006, 11:08 PM
Hello, there.
I have been there many times, know what its like..
The solution is simple but verry important..junk the hard line, buy the tool, and make a new one..every time..
The cost of all the hard line and flexies is totally trivial compared to the cost of brake failure..do not even thnk about using pblaster etc near barkes..
Kind regards
Old 08-20-2006, 02:45 AM
Are you using a flare nut wrench on the hard line and a regular wrench on the soft line?
Sean
1982 SC D-Stock #372
NASA GTS2
1971T restoration in progress, read about it here:
http://911restorationmadness.blogspot.com/
Old 08-20-2006, 07:10 AM
Todd Simpson's Avatar
I'll second David's suggestion...throw it all away and start over. The lines are not irreplaceable at all.
Year ago I bought replacement hard lines from the dealer. I can't remember the price but it wasn't bad. Now I just get straight lines from the auto parts store and bend them to fit. Bring an old line to match the threads and flare type...Japanese, American, are all different.
It is SO nice a few years down the road to work on the brakes with newer lines.
Old 08-20-2006, 07:27 AM
der Mond's Avatar
Thanks for the help, guys. I'm starting from scratch here with brake line knowledge, so:
"buy the tool, and make a new one..every time.."
David, would you be willing to explain which tool and what the procedure is?
"...get straight lines from the auto parts store and bend them to fit. Bring an old line to match the threads and flare type..."
Tod, does this mean that the auto parts store will cut a line to fit and flare the ends for me and put the right size/thread nuts on it, so all I have to do is bend it? So does that mean all I need is the bend tool? Please explain.
Thanks again!!!!
Peace & Thanks,
der Mond
'87 Carrera Coupe
Old 08-20-2006, 11:23 AM
The auto parts store will carry something like 8", 12", 20" and 24" sizes. (Some stores will have a lot of each, some none...may take a few trips.) They will already be flared and have the nuts in place, ready to go. Just buy a bending tool and you're in business.
Old 08-20-2006, 12:50 PM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Kind regards
Why? It's the only way I was able to get mine off. It doesn't really get anywhere near the calipers and rotors/
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 08-20-2006, 05:12 PM
I have found a little heat seems to help. Bleeding the system afterwards is a must anyway since the line has been opened. Heat is the answer to many of my stuborn parts.
Old 08-20-2006, 05:50 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
I believe that davidppp is speaking of a flaring wrench/tool. You can use the original steel line if you cut it just past the stuck flare nut. Now you should have an open steel brake line. Side a new flare nut onto to it and use the tool to "flare" the end and then your new conncetion is complete.
Just a note, if you haven't used a flaring wrench before, practice on some spare steel tubing/pipe until you get it right. There are varying qualities (=prices) of flaring tools available, usually with varying levels of difficulty in learning how to use them properly.
Good luck with what you decide to do!
-Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 08-20-2006, 06:06 PM
der Mond's Avatar
I see that the hard lines are all available from Pelican, actually, and they appear easy enough to get to, except for the left rear, which winds down and around the G50 and then attaches to the "distributor" piece. Have any of you managed to replace that hard line without dropping the rear stabilizer bar and transmission crossmember?
Peace & Thanks,
der Mond
'87 Carrera Coupe
Old 08-20-2006, 07:21 PM
der Mond's Avatar
...and what's the best way to "cut" a brake line cleanly?
Peace & Thanks,
der Mond
'87 Carrera Coupe
Old 08-20-2006, 07:31 PM
I just did this same work on my '84 not 6 hours ago. A few weeks ago I did pads, fluid and SS lines with the exception of the left front SS line. The upper fitting on the short hard line off the caliper started to fail, with a flare nut wrench. I stopped there and ordered a new short hard line from Niello in Sacramento. It only took a couple of days and only cost $10, part # 911 355 605 01. The trip to pick up the part was more than worth it, tremendous eye candy on the lot (new 997 turbo, GT 3, etc. )
I figured for $10 it was worth more than the effort to have a possibly weak line in my brake system. Once I had the new line in hand I PB blasted the fttings and used large channel locks to break loose the bad fitting, then tossed it. The new one went on easily and my job was done and I have confidence in the result.
The line is an "S" about 4" long. Unless you are experienced at fabrication I would not buy the tools to make a new one. The cost benefit on this is an easy call. Just don't screw up the long hard line. Also, I used a cheap flare nut wrench and I would spend a few extra dollars to get a good one before the next time.
Scott
_____________
1984 Carrera Targa
1999 MB E 430 Sport
2006 Chevy Tahoe
Old 08-20-2006, 10:40 PM
MattAlpha's Avatar
Best way to cut a brake line cleanly is to use a small gauge pipe cutter (decreasing it diameter slowly after two or three turns).
Old 08-21-2006, 06:43 AM
LakeCleElum's Avatar
A tubing cutter.....Very cheap in the plumbing dept. of the hardware store....
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 08-21-2006, 06:50 AM
der Mond's Avatar
Thumbs up Eureka!
Just got what appears to be the solution from Pete Zimmermann on Rennlist - Cut the rubber lines, hold the nut on the hard line steady and twist the rubber line nut off of it. Now why didn't I think of that? Should work since my nuts come loose OK. How does that sound?
Peace & Thanks,
der Mond
'87 Carrera Coupe
Old 08-22-2006, 11:53 AM
rs6er's Avatar
Re: Eureka!
Not working for me on my outside LR hose connection.
John
Old 08-22-2006, 05:42 PM
der Mond's Avatar
John,
Exactly how is it not working? Did the rubber line nut not break loose in the first place? What happened?
Dennis
Peace & Thanks,
der Mond
'87 Carrera Coupe
Old 08-22-2006, 06:31 PM
rs6er's Avatar
I cut the hose on the end of the rubber line on the outboard side. I put a long socket on the nut since I can't get any other kind of wrench on it. Holding the small nut on the outside with a flare wrench, I tried to turn the big nut with the socket wrench. When I turn the socket wrench, I can't prevent it from turning the whole thing, including the outboard line. I have been using PB Blaster for a week. This is the only one I have left.
John
Old 08-23-2006, 06:38 AM
Hey John
I was talking with Cheech at Rennwerke in Elmsford about this the other day. I had him check over all the work I had done on the brake system. He has had lines in stock at his shop. If you can't make it work, I suggest you cut the hard line and go pick up a new one from him. They're cheap.
Sean
Sean
NASA GTS2
Old 08-23-2006, 08:20 AM
rs6er's Avatar
I'm still waiting for him to fax me an estimate for my rebuild.
John
Old 08-23-2006, 08:49 AM
