My balls are tight!
I've read as many posts as I can regarding a cv joint disassemble/clean/reassemble. I keep reading about balls just dropping out of the cage. My balls were in tight. They would move back and forth in the opening in the cage but I had to (carefully) pry them out. My question: when I reassemble do I push these balls back in the cage so they dont fall out, or should they just be placed there essentially held in with grease.
Jay Carrauthers
1966 Porsche 911
1988 BMW 325ic
Old 08-28-2006, 10:29 AM
84toy's Avatar
Tight is good. When they are new, you can barely move them. Take the balls out, clean them and set them on a white piece of paper. That will show if they have overheated
Paul S
"Those who say it cannot be done should not interrupt the people doing it"
Old 08-28-2006, 10:33 AM
charleskieffner's Avatar
make sure your BALLS have no rust no dents no cuts no dings and are perfectly smooth. ie. in perfect shape. grease will hold them in if used liberally. use coffee can lids with duck tape to keep in place while moving them around. its kinda like a RUBIKS CUBE!
Old 08-28-2006, 11:01 AM
Grady Clay's Avatar
My balls are tight!
I wish I could say the same for MY Porsche balls.
They are somewhat deflated and limp.
Yes, the CV jont balls are normally tight in the cages.
Best,
Grady
Old 08-28-2006, 11:13 AM
Kelly Bell's Avatar
My balls were tight as well. When its cold, they get even tighter......
Kelly Bell
72 MGB
75 911S
00 Volvo S70
Old 08-28-2006, 11:15 AM
ruf-porsche's Avatar
Do they get smaller in cold water??
HA HA HA
LOL
Old 08-28-2006, 11:51 AM
shrinkage jerry shrinkage!!!!!!!!!! My favorite episode.
but yes tight is good
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 08-28-2006, 12:04 PM
Grady Clay's Avatar
My balls are tight!
These are FACTORY balls, as old and limp as they are. They probably have a Porsche part number.
Careful guys – this might get thrown OT when it is about CJ joints. Oops, I meant CVs.
The CV joint balls are actually ball bearings. I think all ball bearings in the world are American Standard. I think the 108 mm CV joint balls are 7/16” exactly and not some Porsche or Lobro “Unobtanium.”. Try your local bearing supplier.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 08-28-2006, 12:08 PM
Kelly Bell's Avatar
When your balls get older, they often look deflated and limp. I dont know firsthand, but others have told me..............
Kelly Bell
72 MGB
75 911S
00 Volvo S70
Old 08-28-2006, 01:31 PM
kwm kwm is offline
Depending on the age of the balls it is very important to check them for lumps also, just ask Lance Armstong (who I hear has driven Pcars for years w/o checking for lumps)
83SC black on black
01 Chevy S10
08 Buick Enclave
Old 08-28-2006, 01:49 PM
