-   -   Help - How to identify cylinder year/model type? (http://forums.pelicanparts.com/porsche-911-technical-forum/301029-help-how-identify-cylinder-year-model-type.html)
tom1394racing 08-28-2006 09:28 AM
I am trying to identify a a variety of different heads for model type and year (ie P/N).
Is there some way to link the casting number (cast into the head) to the year and model of the head? I have the Porsche PET that allows me to link P/N to the year/model. Can I do this without having to measure the ports and valve sizes on each head?
Early_S_Man 08-28-2006 09:56 AM
Tom,
I have never seen a cross-reference such as you describe, though have wondered many times if such a list exists. The pictures in BA's handbook are incomplete as far as the full range of engine versions, but is just about the only reference I know of ...
The real problem is that the raw casting numbers are too different from the parts system numbers -- differing in the hundreds digit of the middle trio, either for the bare heads, or for the assembled heads with valves!
tom1394racing 08-28-2006 02:27 PM
Warren
Here's a link to a good cross reference table:
http://www.carquip.com/parts/911/engines/cyltbl/index.aspp
Henry Schmidt says that there is a date stamp that will tell model year and narrow the choices down, but that it is necessary to measure the ports and valves to pin down the model.
911quest 08-28-2006 02:33 PM
There is also one started on the early S registry
BK911 08-28-2006 03:35 PM
I thought S heads had a 305 in the casting number. ????
