-   -   3.2 Starting issue (http://forums.pelicanparts.com/porsche-911-technical-forum/301802-3-2-starting-issue.html)
jorian 08-31-2006 01:24 PM
3.2 Starting issue
Car won't start. I usually crank 1-2 seconds and it fires right up. Drove the Auto-X on the weekend with no issues but I did notice a the engine bog twice during the day when I got the throttle.
Car has always had a bit of a hunting idle but not enough for me to fix. Could the ICV havbe packed it in? O2 sensor? CHT sensor?
Just trying to get an idea of what I can do myself before I drag it to a shop.
Thanks in advance!
charlesbahn 08-31-2006 02:06 PM
New DME relay (under the driver's seat) and clean the plug in sockets.
stlrj 08-31-2006 04:26 PM
Bog and hunting idle usually indicates an over rich condition. Might be as simple as having your mixture checked and adjusted.
DW SD 08-31-2006 05:51 PM
I'm thinking you may have a fuel issue. Maybe your filter is plugged or your pump crapped out. If you don't have full fuel pressure it will bog, instantly as if the ignition were turned off.
My pump died once and it wouldn't start. Try a shot of ether (carefully) before cranking and see if it starts and then dies. Do not try to run it on ether, just a spray before cranking. You can also crack a fuel line at the fuel rail and see if there is pressure (not cranking) and immediately after cranking. OR have a friend grab the pump and see if it vibrates during cranking.
Doug
