Kevin Fairchild
Guest
Posts: n/a
HELP!
I am unable to remove one of the 6mm allen bolts on the CV joint. It is rounding off the allen wrench. We have ground the wrench trying to sharpen the edges (trying not to overheat). Wrench keeps slipping. Seems like the allen bolt has been reemed out. Any suggestions?
Old 04-30-2000, 09:13 AM
Early_S_Man
Guest
Posts: n/a
If that particular Allen bolt is a 'goner' as far as reuse is concerned, why not use a pipe wrench or Vice-Grip on the outside ... to get it loose?
Warren Hall
1973 911S Targa
Old 04-30-2000, 10:01 AM
rboylan
Guest
Posts: n/a
Removal would best be accomplished with a nice pair of vice-grips. Not the Sears brand either, the one and only original Porsche of hand tools the vice-grip. Good luck.
Rich
Old 05-01-2000, 05:29 AM
Kevin Fairchild
Guest
Posts: n/a
I received a reply from another list that said to hammer a 12mm socket over the allen bolt head. I tryed this and the socket fit really snug over the allen bolt. I then used a breaker bar to turn the socket. Worked like a charm.
BUT, now I am trying to remove the flywheel and guess what? I have 2 allen bolts that are stripped. There is not enough room to put the 12mm socket over the head of the bolt, so I tryed vice grips. The vice grips kept slipping. I guess it is time to invest in a decent pair. Thanks for the help.
[This message has been edited by Kevin Fairchild (edited 05-01-2000).]
Old 05-01-2000, 12:57 PM
