Does anyone know of a good 911 mechanic in Portland? I just moved here from Seattle and the phone book and Google searches aren't helping.
Thanks!
'77 911 S |
Steve W recommended:
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
Welcome to Portland. The Oregon PCA web site (www.oregonpca.org) lists several shops. You do belong to PCA? The chapter here has 600+ members and has lots of activities. Consider coming out for a few.
I use Mike at Stuttgart for the work I chose not to do myself and have been very pleased. Depending on where you live and your personality, you may find Kurt at Marque Motors, Wayne at Autosports or the folks at Heckmann Thieman more to your liking. If you are looking for support of your track car, Rothsport Road and Race is a great shop. Hopefully I'll see you around.
You could also try Heckmann & Thiemann Motors. The are in SE Portland
2337 S.E. Powell Blvd. Portland OR 97202 503-233-4809 Mark 1986 ROW Targa |
Air Medal or two
what is the problem ??
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
It just won't start and there is gas coming from the manifold. It's a 2.7 with CIS that sat for years. It ran a month ago but I can't get it started now. Could be a clogged fuel injector or the cold start valve... I don't know. There was also smoke slowly leaking out of the exhaust pipe a minute after I tried to start it. Excess fuel burning off?
'77 911 S |
Air Medal or two
could be a gazoomba of things..can someone crank it and you watch ?? (with fire ext in hand !!)
There could be a big red sticker that says "replace me" and I'd still want pro help. I put the car together from the ground up but the engine was complete. I don't mess with internal parts, I once burnt a 1979 Kawasaki KZ 750 to the ground trying to start it with go - go juice. Luckily the fire department was only a block away so they got it put out before the tank exploded.
'77 911 S |
I have used Stuttgart for routine stuff and Rennsport Systems/Rothsport for performance stuff, suspension setup. Both shops have great people.
Troy
Troy Past: 1975 911S Silver Anniversary-rebuilt and sublime. Past: 1988 Carrera-backdated with a 3.6 and all the goodies. Present: 2011 GMC 2500HD with the 6.0 & 4x4!, 2004 Toyota Sequoia (wife's) |
I have good news and bad news, I changed the spark plugs and the car fired right up and ran great! The bad news is that the old plus were completly black after only 200 and then sitting for a month... What is that?
'77 911 S |
