Angry Immobilizer Problems
Sometimes my car starts, sometimes not. There is no ryhme or reason as to when this happens. I have a new battery in the remote so that's not it. Any suggestions are appeciated.
1996 C4
Old 09-09-2006, 08:51 AM
GFCC
Jeff's Avatar
I'm not sure if the 993s are equiped with a clutch switch (car won't turn over unless the clutch is in), but if it is, you may want to bypass that and see if it fixes your problem. This happened to my friends 996. New clutch switch and it started every time.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 09-09-2006, 10:03 AM
ruf-porsche's Avatar
Are you using a remote to start the car?
That could be your problem, some installer hacked into the car electrical system just to install a remote start. If the later PORSCHE is like the later BMW and MERCEDES the key has a transponder in it to initiate the start process, no key in the ignition no start.
Old 09-09-2006, 10:14 AM
