Banned
Rough ride with my 911 SC
Hi there im pretty new to this forum, I have purchased a 82 911 SC and have been working on it like crazy recently. I went about giving it an oil change, changed the distributor cap, spark plugs, blower and just basically cleaning the car up. The other day I was driving it and I noticed the car jerking, when I hit the gas, sometimes is seems like it is misfiring. It hesitates to go when I hit the gas. Other times it goes fine, but when the RPM's are over 3000 the car runs a lot better. Its pretty much when I shift to a gear and speed up early in the gear, thats when is misfires. When I leave the car sitting for a couple days or so and turn on the car black smoke comes out for a second. But if I were to turn it on everyday, everything is ok starts fine. Is that normal? Also the air comming out of the exhaust smellls like crap haha, I know its an old car but any solutions I am looking at getting some new ignition wires the ones on the car look horrible, also I bought a fuel pump havent installed it yet, hope it will help. Your suggestion will be of big help. Thanks -Arvin
Old 09-08-2006, 05:54 AM
ruf-porsche's Avatar
Black smoke after the car been sitting for a couple of days, you got leaky injectors.
Old 09-08-2006, 05:56 AM
Wer bremst verliert
JohnJL's Avatar
Keep it over 3000 RPMs ;-)
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 09-08-2006, 06:01 AM
petrolblue83911's Avatar
is it like that all the time or only when the car is cold or warm?
Old 09-08-2006, 06:50 AM
Take it in for a mixture adjustment.
Old 09-08-2006, 07:51 AM
could be a couple of things. where do you live? im in the valley if youre close i could take a peek and tell you what i think.
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 09-08-2006, 08:46 AM
I have been having similar problems - drained my tank of all the reformulated gas and put in some 100% real gas and the problems got much better. A few more tanks of real gas and mine should be cleared up.
Brendon
80 911SC "Weissach"
77 930 (in pieces)
Old 09-08-2006, 08:54 PM
XLR8'd Member
David 84 911's Avatar
I had a very similar problem however maybe (or maybe not) a little less pronounced...it was solved today with a new Oxygen sensor from pelican parts. Try disconnecting your O2 sensor temporarily, if it solves it, you need a new one....
David (mechanic wanabe)
2002 Carrera 4S (replacement for an 84 coupe)
06 Acura CSX (wife beater)
05 Acura MDX (toy hauler)
http://www.pelicanparts.com/gallery/david_84_911
Old 09-08-2006, 09:16 PM
Somatic Negative Optimist
Gunter's Avatar
Arvin: The stalling when shifting in low RPM is mixture related.
Before you go for a mix-adjust, set the valve clearance.
Do a tune-up and keep a log.
Valve adjust. (You'll need the special feeler gauge)
Mixture adjust. (You'll need the 3mm Allen key)
Timing. (You'll need a timing light)
Of course, good plugs, ignition wires, cap & rotor is a must.
Smoke on start-up after sitting for a few days is normal with these engines.
A Bentley SC Repair Manual can be of help to learn more about CIS etc.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 09-09-2006, 05:36 AM
Blue smoke on start up is normal due to design of the engine, boxer configuration, but black smoke wouold indicate too much gas, which could be leaky injectors.
Old 09-09-2006, 09:12 AM
