47silver's Avatar
targa front window seal reinstall
i bought the targa seal from our host a year ago...and installed it immediately. Did not fit...hmmm, checked this site and discovered that it needs shaved.
today i finally shaved it... I tried a dremel but that was dumb.
I have a heavy old bench grinder, so i took it outside and began to grind away according to the documents on this site.
Much to my surprise it worked and it was easier than i thought to shave it down and have it fit better.
Things i learned:
1. use a bench grinder. I would remove the shields see#5.
2. put something under it to catch the rubber dust. say a large piece of cardboard that you can throw out.
3. wear a mask and googles and a hat the rubber dust goes everywhere. I would not do this inside unless i had a powerful vacuum attached to the grinder.
4. I also had the old seal and used a carpeters duplicator to approximate the cut and depth. gave me some confidence but it is not necessary.
5. My grinder does not have a guard so i was able to slide it under the grinder and let the wheel pull it along.
6. make several passes. Be careful in the corners.
7. Dry install it as many times as needed until the roof fits even with the front roof. I did it 5 timesl.
8. use shop vac to clean everything.
I'll try to post some photo's tomorrow of the seal in place, the duplicator and the old grinder.
1975 911S Targa
Silver Anniversary Edition
Old 09-04-2006, 07:13 PM
Semper drive!
rcecale's Avatar
Great info, thanks for sharing!
As for tomorrow....pics, pics and more pics, please!
Oh, and thanks again for sharing!
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 09-04-2006, 07:30 PM
47silver's Avatar
pics
Randy:
you are welcome, but it is easier than i thought to do...i was really hesitant but was tired of my old top looking like a bad toupe
Just use a good bench grinder and go smoothly and slowly.
I am happy with the result , now i can put the carpet that i bought here in 2004 into the car.
1975 911S Targa
Old 09-04-2006, 07:44 PM
RFR RFR is offline
RFR's Avatar
I'd love to see pics as well!
Old 09-04-2006, 08:37 PM
KCinBR's Avatar
Got them pics ready?????
KC
88 Guards Red Targa (sadly sold )
2005 Boxster S
1st Porsche 73 914 (long gone)
Old 09-05-2006, 03:10 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Thanks a lot...That is the info I need because it is on the winter project list for me...Any pics !!!
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 09-05-2006, 04:25 AM
47silver..great news in addition to the pictures what would be really helpful would be some measurements! I would be very interested in the dimensions of the old seal at various points from the center to below the corners.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 09-05-2006, 05:42 AM
47silver's Avatar
some pics
The attached with notes are what I measured and how i tried to grind the seal. The old grinding wheel worked fine. Keep your fingers on the bottom of the seal. Do not wear long sleeves or a tie.
1975 911S Targa
Old 09-05-2006, 05:46 PM
47silver's Avatar
2nd picture distance
distance from b to c on the second photo is 7 CM.
1975 911S Targa
Old 09-05-2006, 05:48 PM
47silver's Avatar
distance on side window seal
forgot to post the distance on the window column part of the seal,,, i measured 10 mm down on the old seal.
1975 911S Targa
Old 09-05-2006, 05:52 PM
Semper drive!
rcecale's Avatar
Thanks very much for posting the pics!!! Now to take them out to the car and compare. This just moved up to be my priority winter job. Followed closely by a rear wheel bearing replacement.
Randy
One Marine's View
Old 09-05-2006, 06:08 PM
Kudos to you! I found dealing with targa seals and attempting to improve the fit of the roof to be the most painful part of the DIY 911 experience. I solved this problem by switching to a coupe. I do miss the open air experience, but I do not miss the leaks, the noise, and the frustration.
Old 09-05-2006, 06:16 PM
