-   -   So, where does this belong? (http://forums.pelicanparts.com/porsche-911-technical-forum/302956-so-where-does-belong.html)
Chris_1983 09-06-2006 04:27 PM
I have a 1983 911 SC and the truck light does not work. Upon inspection I found this little guy just hang'in there. New car for me and trying to figure my way around.
Thanks for all the help with the fuel pump noise!
http://forums.pelicanparts.com/uploa...1157585199.jpg
Rick V 09-06-2006 05:01 PM
Well being brown I would suspect it is a ground. From the looks of the wire sticking out of the housing it looks like it pulled out of a conector.Start looking around for a round terminal that is bolted to the body in that area. I will look in my 82 and see if I can find it in my car.
Rick V 09-06-2006 05:04 PM
There is a group of ground wires right there next to one of the air vent tubes. See if one of the wires is ripped out from there.
Chris_1983 09-06-2006 06:48 PM
Okay, found the white round connector near the hose. It appears to be a 6 wire connector, but in mine only 5 wires are being used. This is on both sides. In other words, I have 5 wires coming in and going out the other side. With 1 empty connector position on each side.
