-   -   Do we have 1 or 2 O2 sensors on an 88?... (http://forums.pelicanparts.com/porsche-911-technical-forum/303063-do-we-have-1-2-o2-sensors-88-a.html)
bonaturtle 09-07-2006 09:04 AM
my HC's were way too high at my emissions test, thinking I have a bad O2 sensor.
Rot 911 09-07-2006 09:05 AM
You have one.
craigster59 09-07-2006 09:08 AM
There is also an oxygen sensor relay that you should change while you're at it. Around $20
der Mond 09-07-2006 09:22 AM
Why, is that a troublesome relay? Haven't heard of that particular problem...
bonaturtle 09-07-2006 09:37 AM
ah, yeah, found it. gotta find something else to order with it, seeing i can get a sensor elsewhere for cheaper.
craigster59 09-07-2006 10:35 AM
I'm going thru the same thing, high HC's. It's another link in the chain to solving the problem and as long as you're ordering parts the cost ( $20 is high, they can be had for 10-16 dollars) saves a second trip/phonecall if the sensor doesn't solve the problem.
rick-l 09-07-2006 11:35 AM
Relay for an oxygen sensor on an 88????? huh
That coax is supposed to go directly to the DME.
The heater for the OXS is an un-fused lead off the DME relay that also powers the fuel pump. It should be easy to tell if that is working.;)
