Do we have 1 or 2 O2 sensors on an 88?...
my HC's were way too high at my emissions test, thinking I have a bad O2 sensor.
Sean 1988 911 Coupe Blk/Linen 1992 Mercedes-Benz 190 2.3 1999 Honda Accord LX 2003 Kymco People 50 (city killer) |
Friend of Warren
You have one.
Kurt V No more Porsches, but a revolving number of motorcycles. |
There is also an oxygen sensor relay that you should change while you're at it. Around $20
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
Why, is that a troublesome relay? Haven't heard of that particular problem...
Peace & Thanks, der Mond '87 Carrera Coupe Venetian Blue Metallic |
ah, yeah, found it. gotta find something else to order with it, seeing i can get a sensor elsewhere for cheaper.
That coax is supposed to go directly to the DME. The heater for the OXS is an un-fused lead off the DME relay that also powers the fuel pump. It should be easy to tell if that is working.
