Crotchety Old Bastard
EVIL ENGINE for you flat black fans.
I've been putting together an engine to use for fitment purposes for a twin turbo project. After seeing various threads on the virtues of flat black I decided to break out the rattle can and give you fellas an engine for your RATRODS.
If I put this in my Guards Red Turbo will I have hidden cool? HA!
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Perfect!
Looks cool! Brad
'78 911 SC '61 Mercedes 220b '74 Westy 2.0 |
UFLYICU
GO RAIDERS!!!
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Undetectable on radar.
Matthew “Sometimes the questions are complicated and the answers are simple.” |
Brian, are you still looking for parts for that mock up? Let me know what you need still and I will see if I have it here.
looks very cool! Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Guest
Posts: n/a
Me like! Now carry the theme to the outside of the car. MMM
drag racing the short bus
Hides dirt...
The Terror of Tiny Town |
"Hides dirt..."
That is what I was thinking after seeing the painted case. It looks nice with fresh paint yet would hide all the dirt. Not bad. Jeff, thanks for the offer. I do still need a couple of parts. As you can see in the picture there is no shroud/fan heat ducts that would connect to the heat exchangers. I need the assembly for both sides - cracked ducts and rusty tin would be perfect! I also need 930 tin for the front of the engine. I want to use the stock turbo cutouts. An old junk dizzy would be nice as well. Those are the biggies that I can think of right off the top of my head. This has really been a fun project. Building a motor without measuring anything or being conserned with torque specs! Ha! The only down side was cleaning - you just can't believe how filthy this old junk was. Litterally caked on oil grime from 20+ years for the most part. I've used a case of carb cleaner along with several scrapers and old tooth brushes. Nasty.
Longhoods Unite!
+1
Anything and everything should be flat black
1970 911T -- Neglected, oil burning problem, batman smoke 1974 914 2.0 Weber'd -- new project!! **My Wife and I bought our first house in August of 2009, the footprint of the house is just over 1100 sq. ft...my garage is just over 1000 sq. ft. We compromise well **
It's the anti-thesis of bling! I like it almost as much as my dirty, bare metal and oxidized paint 3.2. Flash is so last century.
Joe 85 Carrera 64 Honda Dream - for sale 71 Hodaka Super Rat - keeper |
Back in New England!
RarlyL8,
If you want the flat black paint theme to continue outside of the engine, I have a black turbo look cab. You could put your finished twin turbo engine in it, and make it a real turbo beast for me. Everything would match perfectly, of course I would have to drive it home too... That engine looks great! Please keep us informed. I'm vary interested on how you're going to fit the extra turbo in there and then "plumb it". -Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
Matt,
What I'm thinking to do is start a thread where everyone puts in their ideas. This is purely an exersize to see if it can be done, not "should you do it". The answer to that is NO. My present engine works perfectly and is more powerful than the tranny (and myself) can safely handle. I get into trouble really fast some times. This past weekend I went for a drive and put a towel down in the seat to keep my dirty drawers off the leather. That towel got a little more of a workout that was intended when I hit an off-camber corner a little too hot. Thank God for 315s in the rear! I seriously doubt that I would use the flat black painted parts in my car. I did that just for the RatRod guys sense it seems to be having a surge in popularity.
This is the high heat 1,200 degree paint, right? It works very well.
Don't trust the color stuff which says it goes to 500 degrees, unless you know it will never get that hot.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
It's exhaust system paint, like the stuff Griot sells but a lot cheaper.
Should be OK. If not who would notice?
Re: EVIL ENGINE for you flat black fans.
Milt, you ain't seen nothin' yet.
I'm subscribed. Bring it on.
I read someplace that flat-black adds like 15hp at the rear wheels. It also looks wicked cool.
'75 911S 3.0L '75 914 3.2 Honda J '67 912R-STi '05 Cayenne Turbo '99 LR Disco 2, gone but not forgotten |
disband
love flat black, infact it's my color.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Progress update: Heat exchangers
I installed a set of 993 Bishoff(sp) exchangers with the flipped flanges. I had no idea if these would work in this application. It looks like they might. It's gonna be tight but it could work.
