jryerson
Guest
Posts: n/a
How to tell if you have an exhaust leak or valve noise
My SC has developed a tick on the drivers side when it gets warmed up to about 220'
I believe its either valve noise or exhaust leak
How can you tell if its a exhaust leak?
Old 05-15-2000, 08:51 PM
Early_S_Man
Guest
Posts: n/a
I'm not sure how to describe the difference, other than to say valves are a more metallic, ticking sound, and exhaust leaks are more like a 'spitting' sound ...
Of course, the 'cute' answer is, if you adjust your valves and the mystery noise goes away ... then it wasn't an exhaust leak!
Warren Hall
1973 911S Targa
Old 05-15-2000, 10:39 PM
jryerson
Guest
Posts: n/a
Thanks Warren
It was a metallic sound so I re adjusted my exhaust valves solved the problem
Old 05-16-2000, 10:37 AM
jryerson
Guest
Posts: n/a
PS I picked up a mechanics stethascope at Pep Boys for $15 - it was real handy to locate which rocker was making all the noise along with other uses
Old 05-16-2000, 03:15 PM
