fast idle
when I first start my sc the idle is low almost seems like its going to die, but it does not. I drive it and it eventually warms up.
then it stays at a high idle (2000-2500).
If I shut it off for a few minutes than start it again, it idles normally.
Brad
1983 911 Cabriolet (daily driver)
2000 ML 320 (Shared by teenagers)
2005 Pilot (Wife's)
Old 03-25-2007, 06:29 PM
advance weights stuck in the dist. Usually happens when the ancillaries heat up and expand. Time to take apart and clean up... Use search.
Of course there are about A MILLION OTHER OPTIONS... usually the CIS gets misblamed.
good luck
Shawn
'82 911
previous:
'86 951
'72 914
Old 03-25-2007, 07:14 PM
Mixture incorrect/ improper timing/ fouled plug that clears after running/vacuum leaks/CIS malfunction/advance weights stuck in the dist
good luck
Shawn
'82 911
previous:
'86 951
'72 914
Old 03-25-2007, 07:19 PM
Band.
"advance weights stuck in the dist"
If that's the case, would you be able to "see" this problem with a timing light?
I have the same problem, if less drastic. (idles great until HOT, then about 1500-1600 rpm.)
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 03-25-2007, 07:42 PM
Can you elaborate a little
Brad
2005 Pilot (Wife's)
Old 03-25-2007, 09:23 PM
