What did I remove?
I removed a plug similar to the sump plug, thinking it was the sump plug. Oil came out and so did a 4 inch spring. It is unclear if anything else came out. Doh@!
Thermostat? |
Oil pressure relief valve. I did the same thing. There should be more parts than just a spring. Oil plug is on the side of the lower case...instead of the bottom.
You may want to check your drain pan for the piston in this pic???
http://forums.pelicanparts.com/uploa...1153324320.jpg |
Thanks you guys!
I found the end, but I am missing the piston. Probably down the drain of the oil pan or shot out somewher in the driveway. I will look for it in the am. I appreciate the illustrations/pics. Matt |
| All times are GMT -8. The time now is 04:46 AM. |
