cygtoad's Avatar
What did I remove?
I removed a plug similar to the sump plug, thinking it was the sump plug. Oil came out and so did a 4 inch spring. It is unclear if anything else came out. Doh@!
Thermostat?
_______________________
Unless you change your course, you are likely to end up where you are headed.
'87 Carrera, Black on Black
Old 09-08-2006, 07:37 PM
Oil pressure relief valve. I did the same thing. There should be more parts than just a spring. Oil plug is on the side of the lower case...instead of the bottom.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 09-08-2006, 07:47 PM
Hope this helps.
98 Honda Prelude
22 Honda Civic SI
Old 09-08-2006, 07:57 PM
Early_S_Man's Avatar
Porsche Crest
You may want to check your drain pan for the piston in this pic???
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-08-2006, 08:01 PM
cygtoad's Avatar
Thanks you guys!
I found the end, but I am missing the piston. Probably down the drain of the oil pan or shot out somewher in the driveway. I will look for it in the am.
I appreciate the illustrations/pics.
Matt
Old 09-08-2006, 08:08 PM
