-   -   precise rear decklid width (http://forums.pelicanparts.com/porsche-911-technical-forum/303482-precise-rear-decklid-width.html)
JohnJL 09-09-2006 08:21 PM
I don't have my car here and need to finalize positioning of the supports to mount my rear wing. Could someone please measure the precise edge-to-edge width of their engine cover/ducktail? Should be the same for all 1974-1983 I believe...
thanks!
ruf-porsche 09-09-2006 08:45 PM
I think the lid is not square so depending on where the measurement is taken it will be differen t.
JohnJL 09-09-2006 08:51 PM
Good point,,,how about 2/3rd of the way down, where Jack has his brackets mounted in this thread...http://forums.pelicanparts.com/showthread.php?s=&threadid=302014&perpage=20&pagen umber=2
right at about the leading edge of the ducktail
2.7RACER 09-09-2006 09:08 PM
John,
I have a lid from a middle 80's 911.
The dimension at the top is 38.5".
Tapers down to 34" at the bottom.
9" from the bottom the width is 36".
ruf-porsche 09-09-2006 09:10 PM
If you have the length from the top to the bottom he can make a pattern of the deck lid.
JohnJL 09-09-2006 09:15 PM
Thanks guys, Doug that's what I was looking for. Don't need a pattern, just how far apart the tail should have the built-in wing mounts.
911pcars 09-10-2006 12:59 AM
The width measurement would be more consistent on a factory deck lid, not so precise on a FG ducktail. I suggest if you're going to fabricate something with accurate dimensions, you shoud start from an accurate measurement of your particular deck lid/duck tail.
.... or get a consensus from several owners of the engine compartment opening, then extrapolate from there. Might be closer, but still not as accurate as measuring yours.
Sherwood
