-   -   A/C delete, nearly there............ (http://forums.pelicanparts.com/porsche-911-technical-forum/303652-c-delete-nearly-there.html)
sus911 09-10-2006 04:56 PM
Got most of that A/C crap out of my car over the weekend.
I've owned the car for nearly 20 years, and it never worked so it's a victim of the new diet plan.
Most of it came out cleanly, except for the left hose from the engine bay to the front condensor. It was just too tight and wouldn't come out in either direction so I cut it.
Just need to get the cabin fan out.
Questions:
1) what to do with the centre console and knobs.
2) should the front condensor protection bar stay out? It looks structural to me as it seems to connect the 2 front torsion bar mounts.
3) how have others plugged the holes created by the front condensor fan? I plan to use thin alloy slightly bent and screwed back in with self adhesive foam as a seal.
And by the way, part of a good dietary plan is plenty of excercize, so we're off for a run!!
See ya!
suss
sus911 09-19-2006 01:54 PM
Correction. The biggest pain in the a.... was the compressor bracket.
Most posts say you need to remove the muffler first but my flange nuts were nicely seized so I decided to leave those alone until SSI's.
I had progree, albeit very slow by backing off the 2 nuts retaining the muffler support bracket, allowing the lower compressor nut to back out.
here's all the cr..phttp://forums.pelicanparts.com/uploa...1158702707.jpg http://forums.pelicanparts.com/uploa...1158702751.jpg
All up weight reduction of around 29 kg or 64 pounds.
Seat next, then SSI's & M + K
rs6er 09-19-2006 02:22 PM
I've had mine for 25 years. I did the SSIs & M+K already. I'm about ready to do the delete also.
sus911 09-19-2006 02:28 PM
John, I'm interested whether you did the heater backdate?
Phil
rs6er 09-19-2006 02:34 PM
No. I didn't do the heater backdate. It gets cold where I live and I haven't had the heat on yet with my SSIs.
JK-81SC 09-19-2006 02:35 PM
I'll bet it looks good with all that useless garbage out of the engine bay.
1) Some people take out the console, when they do the a/c removal. I haven't decided whether I'm going that route yet.
2) My car is missing the bar you are talking about, so I need to find out if it is needed!
3) That's exactly want I did. Otherwise water can get in the front during heavy rain, driving through puddles.
I removed my a/c a few months back. I can see the engine and work on it so much easier. I left my evaporator fan in the smugglers box, since I want to rig it up to blow fresh air.
If you want to clear up more junk, do the heater backdate too.
Rick V 09-19-2006 02:43 PM
Leave the fan and the evap box in the car. Simply remove the evap itself and use the fan for ventialtion. I did this and I am glad I did. It also helps with the heat since it blows air fron the little outside vents. Remove the temp control knob and use a little rubber plug for the hole or an alarm light. Keep the fan you will be happy you did. JMO
EdT82SC 09-19-2006 02:50 PM
Re: A/C delete, nearly there............
Questions:
See ya!
suss
1) I took mine out. Not much weight saving, but those ounces add up.
2) The bar is not structural. I took mine out.
3) I did similar. I bought some thin aluminum sheet metal, cut it with tin snips, drilled holes, and screwed the sheet in. I used some silicon caulk to seal it instead of the adhesive foam. I used the same solution on the hole from the pasenger footwell to the smuggler's box. This is where the cabin fan is located. Take out the passenger floor board, and you'll see four screws to get it out.
sus911 09-19-2006 03:05 PM
The Aussie cars don't have the American "smugglers box".
Our evaporator box is in the cabin behind the passenger (left side for us) footrest.
Does that mean the A/C fan is the one behind the dash?
This leaves 3 fans (if the engine compartment fan is deleted)- the A/C fan behind the dash and the 2 footwell blowers.
Will a heater backdate incorporate all these 3?
Rick, can you see from my photos if our systems are different to yours?
Jeff, I believe the bar is not really required but some guys use it as a front jacking point. I'm a little concerned about that and would need reassurance from someone more experienced.
http://forums.pelicanparts.com/uploa...1158706844.jpg [img]
fixed from the bottom I thought it neater
http://forums.pelicanparts.com/uploads8/P92100191158706933.jpg[/img] [img]
see, no smugglers box
http://forums.pelicanparts.com/uploads8/P92100201158706963.jpg[/img]
getting there slowly. Sound insulation gone before it got sucked into the airbox
aknapp 09-19-2006 03:54 PM
Saves money, too. I was recently charged less than normal price on a valve adjust, simply because all the A/C crap (especially the compressor) has been removed.
Who'd've thunk? :)
Rick V 09-19-2006 03:54 PM
Yup some dumbie put your master cylinder on the wrong side! :)
It looks like the same thing as my SC only reversed. It has been a while since I have had the carpeting and stuff out of my car. It's too bad you don't have the ducts, etc like our cars have, it is very nice to flood the car with fresh air since there are no manual vents.
Bearded Viking 09-19-2006 04:01 PM
sus911 -
Do you plan on connecting fresh air to the vents? If you do, let us know what you do please.
sus911 09-19-2006 04:23 PM
Rick,
which ducts do you mean?
Where do they go & come from?
Rick V 09-19-2006 05:07 PM
Rick,
The duct work from the evap box to the dash vents. In my car the air exits the evap box and comes out the center vent and the 2 little side vents. It is completly seperate from the defroster/floor vents. If you keep the evap fan and the housing hooked up (no matter where it is located) and gut the rest of the evap box you should have the same setup. Whereever your ac blew out of is where you will get your fresh air.
brett25 09-19-2006 05:10 PM
good job. dont it feel good to have all that crap out of there? your pics have showed me a couple of items i missed thanks!
my console is gone. i pushed the wires back through the hole then put a black platic plug in looks great. feels great
front condensor fan hole plugged with aluminum sheet, using existing screw holes. 20 minute job
keep the bar, looks like mine has road rash, helps protect the front end i think.
keep fan.
sus911 09-19-2006 05:38 PM
Next project is to get rid of that engine compartment fan.
Me thinks a little more work from what I've read, not only air plumbing but engine tin.
Also not sure what to do with that plastic shroud over the top of the engine. This must be done in conjunction with SSI and new exhaust i believe
sus911 09-19-2006 05:40 PM
thanks Brett.
Would you jack from the bar?
brett25 09-20-2006 09:54 AM
sus, dont jack from the bar. i use the jack points (get a jack pad for that-they slip into the factory jack ports). there are alot of good posts regarding good places for jack stands. this is also where waynes book provides some great advice and know how.
i also got rid of my (non working) engine compartment blower motor. you will have to splice those hoses together so you dont let heat into your engine compartment. i also blocked off the air that comes out of the cooling fan with aluminum sheeting. that i get more air to the cylinders during the summer.
i will try to post a pic
Sweeny Todd 09-20-2006 10:53 AM
Howdy,
If any of you guys want to sell your deleted a/c, I'd be interested in buying it.
Hal
MattAlpha 09-20-2006 12:10 PM
I've got a quick queston. Sorry to hi-jack this thread.
My A/C was deleted by a PO. The fan that was in the smuggler's box is gone. Is there anyway to route ventilation air through thw center and side dash vents?
-Matt
sus911 09-20-2006 12:37 PM
Brett,
I would appreciate it (photo). I drove the car last night and got quite a bit of heat into the engine bay. I was mistaken that this wouldn't happen with the autoheat switched off.
This may require another thread as I removed the blower and wired it straight to the battery and it worked but would not work when hooked up to its connector.
I tested the connector with a multimeter and go a reading of at least 12v................puzzling.
Hal.
I would be interested in selling mine.
Problem is..........Australia.
A possible freight solution is a good friend of mine works for QANTAS and does shifts up to LA quite regularly. He is bringing me back some SSI headers, oil lines and M + K muffler back on next trip (around 4 weeks).
Question is then how to Houston. Maybe just sea freight the lot?
Matt
I'm no means an expert but I am looking at doing the same thing so as to use those centre vents.
I think it's purely a plumbing/ducting issue.
I'll be looking at that over the weekend.
Phil
brett25 09-20-2006 12:48 PM
MAtt,
yoiu could buy an aftermarket fan (like one that goes into a VW Bug) and hook up the hoses. they have the same electrical connections and will run off of the switch on the console. i am in the process of doing that with my car.
Yellowbird RS 09-20-2006 01:38 PM
Done a og time ago. also delate the dash controlls and replace it with a stero deleate plate with 2 racing switch 1 for a front oil cooler fan and he other for turn on the fog lights.
http://forums.pelicanparts.com/uploa...1158788333.jpg
john d 81SC 09-20-2006 08:02 PM
sus,
Any idea of the HP gain w/o your A/C (excluding the weight of all the removed bits)? Thank you!
sus911 09-20-2006 08:43 PM
The only gain excluding weight is no fan turning compressor which is negligible because it has a clutch.
Butt dyno and tells me car is lighter and more spritely- definitely.
Ride height has come up 1/2" or so.
I did take out spare, tools, jack etc. plus some trim which has shaved some weight off.
I also put on the Rennline strut brace and the car is really firm and nimble.
Next step is install the TTE's, racing seat then corner balance etc.
I'm roughly adjusting the ride height down and have it at around 25.5F 25R but would like it lower I think.
It's getting progressively better!
Mysterytrain 09-21-2006 05:27 AM
I'm curious about one of the parts you have in the 1st picture you posted. I've circled it. It doesn't seem to be something that I've seen before in US market cars. When the A/C was operational what vents did it flow from.
There are a few posts explaining how to remove the rear blower from the engine compartment and just use the footwells. The engine compartment controller needs to be modified.
http://forums.pelicanparts.com/uploa...1158845216.jpg
brett25 09-21-2006 09:42 AM
Sus,
i recommend the an Odyssey motorcycle battery also. I have one and alot of guys on this forum also have them. i think its the 640 (do a search) it only weighs 14lbs and has no problem cranking the car. it will work for you if you in the Australian climate. also i recommend getting rid of your back seats. they are heavy and useless. finally, you could delete your windshield washer reservoir. with fluid that sucker weighs 20 lbs!
sus911 09-21-2006 03:45 PM
Ron.
It seems our cars are somewhat different. No smugglers box and the avaporator and fan resides in the cabin behind the passengers (left side) footrest.
When the A/C was operational, is used the center vents on the dash only to my recollection.
The part you circled is from connects the air between the 2 footwell blowers , is ducted to the eveporator/fan and also connects through the firewall to windscreen ducts.
I think I know about the thread dealing with the egine comp. controller modification, but its a little complex.
Do you know of any others?
sus911 09-21-2006 03:47 PM
Sorry Ron, forgot to paste the link to the other thread........
http://forums.pelicanparts.com/showthread.php?s=&threadid=258473&perpage=20&pagen umber=2
Mysterytrain 09-22-2006 06:04 AM
LOL, that was the thread I was refering to. Its actually a very simple modification. You remove the tin cover from the engine compartment controller and jumper the reed switch. The autoheat system operates the way it always did except the rear blower is removed.
Baby 02-22-2011 08:34 PM
What is this thing that looks like a mirror where the front air condenser used to be?
Originally Posted by sus911 (Post 2821412)
Thrasher 02-23-2011 06:49 AM
Looks like just a piece of sheet Aluminum he cut to fit the opening where the front condensor fan formerly sat. This is just to keep water/dirt/rodents out of the trunk.
Baby 02-23-2011 07:33 AM
I've got one, too. It has almost a mirror finish. Kind of mysterious...
Beartooth 02-23-2011 08:20 AM
Rick and Jk, I too am debating on the a/c delete. The PO of my car already deleted most engine compartment components but I would like to take it further. No need for A/C in Montana. I did a search but did not find a whole lot on exactly what should come out. I too would like to utilize the fan for fresh air. Can you point me in the direction i should follow. I would like to get all mechanicals done on the car before paint next winter.
mickey356 02-23-2011 11:44 AM
Beartooth,
Theres alot of ac delete threads that'll steer you in the right direction.
If it's any help I just started with the compressor and traced everything forward. Getting the lines out was the hardest part, as well as filling the old holes. A bentley or Waynes book also help trace components.
I took everything out. I don't see the need for fresh air being blown into the cabin through vents when I have two windows that let plenty of fresh air in ;)
Plus what good is a smugglers box when it's full of car crap? ;)
Woodyhfd 02-24-2011 02:07 PM
Look here for fresh air through the center vent info:
http://forums.pelicanparts.com/porsche-911-technical-forum/478553-fresh-air-through-center-vents.html
