A/C delete, nearly there............
Got most of that A/C crap out of my car over the weekend.
I've owned the car for nearly 20 years, and it never worked so it's a victim of the new diet plan.
Most of it came out cleanly, except for the left hose from the engine bay to the front condensor. It was just too tight and wouldn't come out in either direction so I cut it.
Just need to get the cabin fan out.
Questions:
1) what to do with the centre console and knobs.
2) should the front condensor protection bar stay out? It looks structural to me as it seems to connect the 2 front torsion bar mounts.
3) how have others plugged the holes created by the front condensor fan? I plan to use thin alloy slightly bent and screwed back in with self adhesive foam as a seal.
And by the way, part of a good dietary plan is plenty of excercize, so we're off for a run!!
See ya!
suss
cheers,
Phil
84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies.
Old 09-10-2006, 05:56 PM
Correction. The biggest pain in the a.... was the compressor bracket.
Most posts say you need to remove the muffler first but my flange nuts were nicely seized so I decided to leave those alone until SSI's.
I had progree, albeit very slow by backing off the 2 nuts retaining the muffler support bracket, allowing the lower compressor nut to back out.
here's all the cr..p
All up weight reduction of around 29 kg or 64 pounds.
Seat next, then SSI's & M + K
cheers,
Phil
Old 09-19-2006, 02:54 PM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
I've had mine for 25 years. I did the SSIs & M+K already. I'm about ready to do the delete also.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 09-19-2006, 03:22 PM
John, I'm interested whether you did the heater backdate?
Phil
cheers,
Phil
Old 09-19-2006, 03:28 PM
rs6er's Avatar
No. I didn't do the heater backdate. It gets cold where I live and I haven't had the heat on yet with my SSIs.
John
Old 09-19-2006, 03:34 PM
JK-81SC's Avatar
I'll bet it looks good with all that useless garbage out of the engine bay.
1) Some people take out the console, when they do the a/c removal. I haven't decided whether I'm going that route yet.
2) My car is missing the bar you are talking about, so I need to find out if it is needed!
3) That's exactly want I did. Otherwise water can get in the front during heavy rain, driving through puddles.
I removed my a/c a few months back. I can see the engine and work on it so much easier. I left my evaporator fan in the smugglers box, since I want to rig it up to blow fresh air.
If you want to clear up more junk, do the heater backdate too.
Jeff
1981 911SC Coupe - SSI's + Dansk, MSD, AC delete, Heater Backdate, Euro ride height, polygraphite bushings, Rennshift
1998 F-150 4x4 - Snow Time
1998 Yamaha WR400 - Mountain Ride
Old 09-19-2006, 03:35 PM
I'm with Bill
Rick V's Avatar
Leave the fan and the evap box in the car. Simply remove the evap itself and use the fan for ventialtion. I did this and I am glad I did. It also helps with the heat since it blows air fron the little outside vents. Remove the temp control knob and use a little rubber plug for the hole or an alarm light. Keep the fan you will be happy you did. JMO
Old 09-19-2006, 03:43 PM
Where is that wrench?
EdT82SC's Avatar
Re: A/C delete, nearly there............
Questions:
See ya!
suss
1) I took mine out. Not much weight saving, but those ounces add up.
2) The bar is not structural. I took mine out.
3) I did similar. I bought some thin aluminum sheet metal, cut it with tin snips, drilled holes, and screwed the sheet in. I used some silicon caulk to seal it instead of the adhesive foam. I used the same solution on the hole from the pasenger footwell to the smuggler's box. This is where the cabin fan is located. Take out the passenger floor board, and you'll see four screws to get it out.
Ed T.
1982 911SC
Porsche Wallpaper
Old 09-19-2006, 03:50 PM
The Aussie cars don't have the American "smugglers box".
Our evaporator box is in the cabin behind the passenger (left side for us) footrest.
Does that mean the A/C fan is the one behind the dash?
This leaves 3 fans (if the engine compartment fan is deleted)- the A/C fan behind the dash and the 2 footwell blowers.
Will a heater backdate incorporate all these 3?
Rick, can you see from my photos if our systems are different to yours?
Jeff, I believe the bar is not really required but some guys use it as a front jacking point. I'm a little concerned about that and would need reassurance from someone more experienced.
[img]
fixed from the bottom I thought it neater
http://forums.pelicanparts.com/uploads8/P92100191158706933.jpg[/img] [img]
see, no smugglers box
http://forums.pelicanparts.com/uploads8/P92100201158706963.jpg[/img]
getting there slowly. Sound insulation gone before it got sucked into the airbox
cheers,
Phil
Old 09-19-2006, 04:05 PM
Saves money, too. I was recently charged less than normal price on a valve adjust, simply because all the A/C crap (especially the compressor) has been removed.
Who'd've thunk?
al
89 Carrera (gone )
05 Boxster ()
Old 09-19-2006, 04:54 PM
I'm with Bill
Rick V's Avatar
Yup some dumbie put your master cylinder on the wrong side!
It looks like the same thing as my SC only reversed. It has been a while since I have had the carpeting and stuff out of my car. It's too bad you don't have the ducts, etc like our cars have, it is very nice to flood the car with fresh air since there are no manual vents.
rhymes with targa
Bearded Viking's Avatar
sus911 -
Do you plan on connecting fresh air to the vents? If you do, let us know what you do please.
Old 09-19-2006, 05:01 PM
Rick,
which ducts do you mean?
Where do they go & come from?
cheers,
Phil
Old 09-19-2006, 05:23 PM
I'm with Bill
Rick V's Avatar
Rick,
The duct work from the evap box to the dash vents. In my car the air exits the evap box and comes out the center vent and the 2 little side vents. It is completly seperate from the defroster/floor vents. If you keep the evap fan and the housing hooked up (no matter where it is located) and gut the rest of the evap box you should have the same setup. Whereever your ac blew out of is where you will get your fresh air.
Old 09-19-2006, 06:07 PM
brett25's Avatar
good job. dont it feel good to have all that crap out of there? your pics have showed me a couple of items i missed thanks!
my console is gone. i pushed the wires back through the hole then put a black platic plug in looks great. feels great
front condensor fan hole plugged with aluminum sheet, using existing screw holes. 20 minute job
keep the bar, looks like mine has road rash, helps protect the front end i think.
keep fan.
1980 911 SC Coupe
1987 944
Old 09-19-2006, 06:10 PM
Next project is to get rid of that engine compartment fan.
Me thinks a little more work from what I've read, not only air plumbing but engine tin.
Also not sure what to do with that plastic shroud over the top of the engine. This must be done in conjunction with SSI and new exhaust i believe
cheers,
Phil
Old 09-19-2006, 06:38 PM
thanks Brett.
Would you jack from the bar?
cheers,
Phil
Old 09-19-2006, 06:40 PM
brett25's Avatar
sus, dont jack from the bar. i use the jack points (get a jack pad for that-they slip into the factory jack ports). there are alot of good posts regarding good places for jack stands. this is also where waynes book provides some great advice and know how.
i also got rid of my (non working) engine compartment blower motor. you will have to splice those hoses together so you dont let heat into your engine compartment. i also blocked off the air that comes out of the cooling fan with aluminum sheeting. that i get more air to the cylinders during the summer.
i will try to post a pic
1980 911 SC Coupe
1987 944
Old 09-20-2006, 10:54 AM
Sweeny Todd's Avatar
Howdy,
If any of you guys want to sell your deleted a/c, I'd be interested in buying it.
Hal
Old 09-20-2006, 11:53 AM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
I've got a quick queston. Sorry to hi-jack this thread.
My A/C was deleted by a PO. The fan that was in the smuggler's box is gone. Is there anyway to route ventilation air through thw center and side dash vents?
-Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 09-20-2006, 01:10 PM
